Ricoh MP C307 Error 255 While Updating Firmware
  • iboam
    • Jul 2022
    • 4
    Hi everyone im new here, just bought a Ricoh MP C307 and had some issues setting up wireless connection so upgrade the firmware by ethernet so now im getting this error Error 255 almost at the end of the process and none of the applications are working right now, then every time i reboot the printer get a message
    Waiting for firmware update data...
    IPV4 address: XXX.XXX.XXX.XXX
    Please wait.
    Any Solution ???
    i tried copying usb:->package->
    D2965430V.pkg and got same error Failed to update screen Software. Error: 255
  • copier tech
    • 8164
    Re: Ricoh MP C307 Error 255 While Updating Firmware
    Please wait.
    Any Solution ???
    Try updating the firmware via SD card this is quicker & more reliable.
    โ€‹
    • GIUBOSS
      • 1436
      It is recommended to update the firmware with the SD card for this machine, you need to download the new firmware version
      on a Secure Digital (SD) card. The SD card is inserted into the SD card slot 2 on the rear left side of the
      controller box.
      If the ROM update does not complete successfully for any reason, then in order to ensure the correct
      operation of the machine, the ROM update error will continue to show until the ROM is updated
      successfully.
      In this case, insert the card again and switch on the machine to continue the firmware download
      automatically from the card without the menu display.
      • Gift
        • Mar 2011
        • 2459
        Not shure if this will work if an update via different method failed and needs to be resumed but it's worty a try. One might better use the modules instead of package then. First of all I'd try the key combo Yellow-1-4-3-c-c-c (or 5x c) if you can access the ten key pad - that might remove the "incomplete update flag" and allowing the machine to boot normally and acceppt an SD card update.
        • iboam
          • Jul 2022
          • 4
          Ok, i did the sd card option and got the same error, maybe is the firmware. Where may i get the default firmware for MP C307 ?
          • davel
            • Oct 2011
            • 1107
            Make sure firmware file extension is .fwu, or get a trained tech to do it. Surely you have the machine on a service contract.
            • TonerMunkeh
              Professional Moron
              • 3865
              Please wait.
              Any Solution ???
              Okay, let's start from the beginning. Do you have the GW Wifi option or are you just using the panel Wifi? Be aware the panel Wifi only allows you to print, no scanning or @remote.
              Second, when the machine is powered on as suggested previously press Yellow - 1 4 3 - C x 5. The machine should beep and then after a reboot should boot normally.
              When it does, put the *.pkg file in a folder called "romdata" on the root of a FAT32 formatted SD card, placed in slot 2 on the side of the machine. This should allow the machine to install the package.
              Bear in mind not all firmware files are included in the package, i.e. Powersave, this causes SC992 on the 307 so it would be an idea to download the rest.
              Hit it.
              • iboam
                • Jul 2022
                • 4
                unfurtunately does not have a support contract
                • copier tech
                  • 8164
                  This is incorrect.
                  You need to put the .pkg file in a folder called 'package'
                  โ€‹
                  • iboam
                    • Jul 2022
                    • 4
                    This is incorrect.
                    I did and sd card is on the 2nd slot it but does not work, where do i get the firmware file ??? O got the one on the temp folder with the update tool
