Mp9002 firmware feedback (good news)
  • luca72
    • Oct 2017
    • 1710
    I guy, today, during an intervention for other problem, i discover that the new firmware for mp9002 among the various benefits, it removes that annoying long cycle of start-up at power-up!...(most likely the system / copy module)...i cant belive it!....long last!.. can you try it too?
    "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
  • UNICORNico
    • May 2018
    • 308
    Re: Mp9002 firmware feedback (good news)
    I need to try this!
    (I'm excited) I have to prove that's true...
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • luca72
      • Oct 2017
      • 1710
      Originally posted by UNICORNico
      I need to try this!
      Yes, let me know thanks
      • GIUBOSS
        • 1385
        Initially my trick was to open and close the front door and it immediately indicated Ready)
        • anothertech
          • 1757
          I don't see anything about it in the release notes.
            • 37047
            There was an SP setting for the B140/B246 Series for Warm Up Short Mode.It is still there in the MP 9002 service manual. The firmware probably changed the default from 2 to either 0 or 1. It also affects SP 3903-001 Drum Rotation Time Extension Mode ON/OFF. See service manual.
            • luca72
              • Oct 2017
              • 1710
              me too, then I checked the txt file, and it didn't write anything
              • luca72
                • Oct 2017
                • 1710
                you know, I've never noticed, I'll try another one that I have not updated
                • luca72
                  • Oct 2017
                  • 1710
                  Controls when corona wire cleaning is done to adjust the length of time that is
                  necessary for startup.
                  [0~2/1]
                  0: Charge corona wire not cleaned when the machine is turned on.
                  Warmup Time: 30 sec. (Short Process Control is done)
                  1: Charge corona wire cleaned only when the machine is turned on.
                  Warmup Time: 30 sec. + 40 sec. (for cleaning) = 70 sec. (Short Process Control
                  is done)
                  2: Normal startup procedure at power on:
                  Warmup Time: 240 sec. (Full Process Control is done; same as B064)
                  • Potential sensor calibrated
                  • Drum starts to turn when fusing unit gets to the warmup temperature (not
                  done during Short Process Control)
                  • Potential sensor readings are used to adjust development bias, grid voltage,
                  laser diode.
                  • ID sensor calibrated (not done during Short Process Control)
                  • TD sensor calibrated (not done during Short Process Control)
                  maybe they set all this in one shot (?) ... anyway I hated that wait
                  6002 and 9002, were the only ones so long, the others older, and the newer ones start immediately
                  • fbkhan3
                    • May 2012
                    • 421
                    It was only possible after 4 minutes, i have been doing this the same with 9001,9002 series.
                    (Machines with Thicker Hot Roller).
                      • 37047
                      All that needed to be changed was the setting, 0 1 or 2, of the SP 3904-001. 1 byte of data. FYI, I have been doing this with martini in school districts for years. Teachers don't like waiting.
