Ricoh MPC6003 - hight pitched noise
  • Kenny
    • Jun 2009
    • 530
    Hi guys,
    got a MPC6003 with a high pitched noise which is sounding like its from the fuser,
    when i turn the machine on its does the noise, then goes after 20-30 seconds in till a print job is started then happens again.
    we have just changed the heating sleeve + heating element with the oil on the fuser as was torn.
    is there anyway to attach a video as i do have a recording.
  • GIUBOSS
    • 1437
    Re: Ricoh MPC6003 - hight pitched noise
    Originally posted by Kenny
    Hi guys,
    Follow the PM counter, you will probably also have the finished pressure roller
    • ltdiniz
      Supervisor de Campo
      • Mar 2021
      • 98
      PM sent
      About BT Ricoh from something about Noise on the MP C6003 model.
      I hope to have help.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Hi guys,
        When the black pcdu goes overlife on the 03/04 range you will hear a high pitched squeal.
        I've heard it so many times that I can pick it as soon as I walk into a business...even if the customer isn't complaining about it.
        Check the PM counter list.
          • 37556
          Usually caused by excessive wear of the lubrication bar.
          • MIKON
            • Jul 2015
            • 188
            i would try to isolate the the noise by using output mode sp5804
            • Kenny
              • Jun 2009
              • 530
              Hi guys,
              will look into your suggestions and will report back with an update!
              much appreciated!
              • RustySprocket
                • Mar 2020
                • 19
                I have seen the ITB assembly squeal like an absolute banshee on these copiers. The plastic rollers in the exit unit as well are known squeakers. If you dont find the fuser or one of the pcu's to be the cause, check those out.
                • UNICORNico
                  • May 2018
                  • 308
                  Hi guys,
                  It would be great if you could provide us with a recording of the sound and some more precise indication of where you think the noise is generated.
                  "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                  • Gift
                    • Mar 2011
                    • 2459
                    high pitch noise can also come from the drum units if they are getting old and there's not enough lubrication/toner on the blades or the blade's rubber.-compound become too hard.
                    ...OK I just notice this has been already suggested, we'll I second on that^^
                    • luca72
                      • Oct 2017
                      • 1791
                      I have a same problem with our mpc6003, here the we using for internal use, She emit a whiste, in someone condiction, but i dont have never time for look It, at ear, not seem a pcdu, but some bushing, but i dont put my Hand on Fire.
                      "I'll be back"
                      • Gift
                        • Mar 2011
                        • 2459
                        You can quick-check the PCUs by getting them out, shaking bit and turning all drums by hand a little bit back + forth a couple of times - this will put some "fresh dirt" on the cleaning blades and eliminate the noise (not for long, of course).
                        • luca72
                          • Oct 2017
                          • 1791
                          this i did not, i will try, but i tried all the sp out checks, and i could not replicate the whistle
                          "I'll be back"
                          • Gift
                            • Mar 2011
                            • 2459
                            with all process speeds? Does the MPC6003 use a discrete drive for dev or a clutch? Sometimes you must toggle several stuff simultaneously to get the parts really moving.
                            I thing I also heard subtle noise from the dev units before so that's the next thing I'd check.
                            • DRichard
                              • May 2008
                              • 482
                              My apologies friend, but I have been following this thread since your original post...perhaps it is just my advanced age, but I haven't heard a damned thing!
                              "Enjoy every sandwich."
                              -- Warren Zevon
