ricoh 1075 hang
  • Rezaarsenalyyyy
    • Mar 2020
    • 25
    [Jamming] ricoh 1075 hang
    hi experts
    My machine stop in middle of work after about 1 minute without any codes.
    other symptoms:
    it doesnt work when fusing temprater control is "1" and sc 543 appears.
    after off/on the hang goes away for another 1 minute.
    I do sp 5804 for main motor it works,after main motor I selected 5804__fusing exit motor and machine hanged again.
    PSU board was repaired 1 mounth ago .
    whats your opinion?tnx alot
  • rthonpm
    • Aug 2007
    • 2847
    Re: ricoh 1075 hang
    It's a twenty year old machine. Boards and parts are going to mainly be second hand at this point at best, if you can even find them.
    Find a modern machine to replace it.
    Sent from my Pixel 6 Pro using Tapatalk
      • 37056
      Re: ricoh 1075 hang
      Originally posted by Rezaarsenalyyyy
      hi experts
      other symptoms:
      SC 543 is a fusing unit overheat error. It is either a bad thermistor, power supply or bad BCU. Time to replace the dinosaur.
      • mikadonovan
        • May 2008
        • 2931
        Re: ricoh 1075 hang
        I remember on these models a fault would occur where the machine would say "printing", but would lock up and do nothing. This always ended up being a failed HDD.
        NEVER ASSUME ANYTHING
        • luca72
          • Oct 2017
          • 1711
          Re: ricoh 1075 hang
          hi experts
          other symptoms:
          try to replace all thermistor and the two termoswitch.
            • 37056
            Re: ricoh 1075 hang
            The center thermistor is a non contact POS that most likely is no longer available.
            • eccelobo
              • 113
              Re: ricoh 1075 hang
              I bet it is the power supply. It happened to me. Good luck!
                • 37056
                Re: ricoh 1075 hang
                The only time I have ever had to replace a power supply was when a screw got dropped into it. I have had many non contact thermistors die.
                • Rezaarsenalyyyy
                  • Mar 2020
                  • 25
                  Re: ricoh 1075 hang
                  tnx
                  • Rezaarsenalyyyy
                    • Mar 2020
                    • 25
                    Re: ricoh 1075 hang
                    Checked all boards on another machine,all that were without problem.
                    LD,Laser wrere ok.
                    used 5804 31 with fusing in and hang.
                    580431 without fusing and resolved.
                    open and close fusing.maybe fusing short conection was the cause,or fusing not was incorrect place.
                    it was new problem for me, machine didnt appear any codes and not work.
                    old or new machine not important,important is resolve and repair them.anybody even a child know new machines are better
                    • Rezaarsenalyyyy
                      • Mar 2020
                      • 25
                      Re: ricoh 1075 hang
                      tnx
                        • 37056
                        Re: ricoh 1075 hang
                        LD,Laser wrere ok.
                        SP 5804 is totally useless for trouble shooting a fusing unit error code. If you do not have a new fusing unit to put in it, the machine is now only good to use as a boat anchor.
                        • fbkhan3
                          • May 2012
                          • 421
                          Re: ricoh 1075 hang
                          hi experts
                          other symptoms:
                          You had a pinched thermistor wire under top cover screw or a fuser lamp wire insulation peal off somewhere with fusing case these are old units and hundreds of repairs and replacement have been done so this is always suspected.
                          • khaled_abosere3@yahoo.com
                            Head technical support
                            • Mar 2012
                            • 169
                            Re: ricoh 1075 hang
                            afficio 2051 "Please Wait"
                            Follow this link
                            Sent from my CPH2239 using Tapatalk
                              • 37056
                              Re: ricoh 1075 hang
                              Follow this link
                              Totally different Service Code.
