ricoh c5100 pro code SC442
  • leonardcahill
    • Nov 2019
    • 23
    [Error Code] ricoh c5100 pro code SC442
    Running lots of labels and the machine blew a code SC442. Any suggestions. Seems the lift tray at the feeder goes down and skips gears, then blows the code. Help! Thankyou
    • 37556
    Re: ricoh c5100 pro code SC442
    And the service manual says, ITB lift sensor YMC. Detects whether or not the YMC transfer rollers are in the lifted position.
    • dalewb74
      • Feb 2018
      • 1162
      i searched for the error in the service manual. it went right to the 442 code..
      • anothertech
        • 1771
        Check this out, possible solution?
        SC442.pdf
        • mrwho
          Major Asshole!
          • 4299
          [ATTACH]54324[/ATTACH]
          x2. Had that same situation once. Definitely check the motor @ the back of the machine.
          Mascan42
          Ibid
          • leonardcahill
            • Nov 2019
            • 23
            Replaced the motor in the back, it self destructed. New Code 398-04 and 540 has now emerged. Any takers. Thanks guys
              • 37556
              Do you even have a service manual? If you don't, you should not be working. Both of those codes are in the service manual to include which 2 motors they refer to.
              • leonardcahill
                • Nov 2019
                • 23
                The manual that we have doesn't have this procedure in it. Got a link? Manual? Advice . Thanks
                • leonardcahill
                  • Nov 2019
                  • 23
                  [QUOTE=mrwho;2190360]x2. Had that same situation once. Definitely check the motor @ the back of the machine.
                  See below: followed the bulletin and replace the motor with one from a spare / parts machine. Now we have new codes. FML
                    • 37556
                    Where did you get it, from a Cracker Jacks box. I have the a copy of the original printing and both error codes are listed. OBTW they are not a procedure, they are error code listings.
                    • leonardcahill
                      • Nov 2019
                      • 23
                      Motor replaced, all codes cleared now. Back in business. Thanks so much for the help guys. You all Rock!!!
