mp c306z application site
  • mido2020
    • May 2022
    • 18
    My applications site is not available on the screen. I wonder how can I install it again. When I auto update the machine through RFUT I don't receive it. It is hard to install apps without it.
    • 37515
    Re: mp c306z application site
    Another end user has screwed up his entry level machine by trying to use RFUT, Ricoh Fuck Up Tool. Hire a trained tech to fix your FU.
    • anothertech
      • 1771
      Yeah I gotta agree, that RFUT seems to be more trouble than it's worth.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Great idea, lousy execution.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Even in RICOH manufacturers training course we had all kinds of issue trying to use RFUT...the trainer gave up in the end.
          • copier tech
            • 8164
            Update the package & Cheetah firmware this will re-add the missing app(s)
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              I think this is an end user...no access to firmware.
              If so, he will need to call a tech.
              • mikadonovan
                • May 2008
                • 2931
                I don't think there is package firmware for this model. Too old, maybe.
                NEVER ASSUME ANYTHING
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  There is a Package software available, version 15.00 is the latest I found.
                  It is not on TSRC for some reason, but it is on RFG eSource.
                  It contains the Application Site firmware:
                  Application Site [M2a_zoo]
                  D2411467J Ver. 1.05.01 -> D2411467K Ver. 1.05.02
                  That model is also on RFUT, but I don't trust anything that site has to offer...been burned too many times.
                  Sounds like you will need an onsite tech to install.
                    • 37515
                    TSRC is simply links to what is on eSource, and someone has to take the time to add them. Doesn't always happen. With Custom/Special firmware it used to be a 50-50 chance to find it on TSRC.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      At one time the CVM packs (remote install Java firmware) only lived on RFG eSource.
                      • mido2020
                        • May 2022
                        • 18
                        Thanks for you all . I updated the machine using D1965406T.pkg . I now have all the new applications . Except for print/scan(memory device) . I can't find it anywhere. Is it necessary to activate something to make it appear
                        • mido2020
                          • May 2022
                          • 18
                          I see that some applications are not activated . So how can I activate them
