SC623-00
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    SC623-00
    Hello everyone. I have a MP9002SP that randomly gives me the fault SC623-00. Turning the machine off and on normally goes.
    I have checked the wiring and updated the firmware but still with the problem. any ideas?
    Field technician since 1994
    • 37556
    Re: SC623-00
    Directly from the service manual:
    BCU-PFB communication error
    • Harness connectors between BCU and PFB loose, broken, disconnected
    • Serial line connection unstable
    • External noise on the line
    • BCU defective
    • PFB defective
    • anothertech
      • 1771
      Re: SC623-00
      Got this from another forum, hope it helps.
      "Had this problem today. The SC623 was coupled with an intermittent "load tray 1" message. On the right tandem tray, I found the black wiring harness that runs next to the front solenoid, was shorting out against the middle slide rail. The wire harness ran even with the black plastic rail slide. I taped the harness back up and using a zip tie, routed it away from the slide rail."
      • bat
        • Sep 2008
        • 140
        Re: SC623-00
        Raplace HDD.
        • luca72
          • Oct 2017
          • 1791
          Re: SC623-00
          check integrety and reset cable from PFB and BCU, and check fuse FU105
          "I'll be back"
          • apump
            • Mar 2009
            • 160
            Re: SC623-00
            replace the harness (D0625701) that goes to feed assy 1,2,3. runs under the waste toner bottle. its pretty easy to replace. that fixed 1 of mine and the soleniod wiring on right side being cut was a fix for the other issue i had.
            • UNICORNico
              • May 2018
              • 308
              Re: SC623-00
              Being somewhat random and if the wiring does not show problems of damaged wires, I would try to use some Ferrite Core, to attenuate the electrical noise.
              "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
              • luca72
                • Oct 2017
                • 1791
                Re: SC623-00
                [ATTACH=CONFIG]54694[/ATTACH]
                good idea!...with two, or more turn around the nuke
                "I'll be back"
