pro c5200s paper jam on way out!!
  • Marwanalhajbi
    • Jul 2018
    • 72
    i have a multi pro c5200s jamming when paper come out from exit unit, mainly you need to pull it out to prevent jamming, specially on high thickness like 350 matte or glossy,
    any ideas what should i replace??
    best regards
  • davel
    • Oct 2011
    • 1104
    Re: pro c5200s paper jam on way out!!
    Is that stock within specifications?
      • 37491
      Probably not.
        • 37491
        Unless you are doing 2 sided try set for face up exit. That way thick and slick papers do not have to make all the bends to go down through the duplex section.
        • Marwanalhajbi
          • Jul 2018
          • 72
          unless you are doing 2 sided try set for face up exit. That way thick and slick papers do not have to make all the bends to go down through the duplex section.
          i'm not even making duplex,it occurs on one side or tow sides
          • dalewb74
            • Feb 2018
            • 1153
            being a production copier, i would recommend calling a trained tech. to handle this issue.
            • anothertech
              • 1770
              What's the jam code?
              • Marwanalhajbi
                • Jul 2018
                • 72
                well it supposed to be me
