Aficio MP c306/c307
  • pasion1
    • Nov 2020
    • 15
    Aficio MP c306/c307
    Good, in an Aficio MP C307, it tells me that one of the cartridges is not installed, I already cleaned the chip and also changed it. What can it be? Thanks
  • Gift
    • Mar 2011
    • 2459
    Re: Aficio MP c306/c307
    Probably the contacts in the back of the machine or obstacles/dirt in that area.
    • pasion1
      • Nov 2020
      • 15
      use contact cleaner.
      • dalewb74
        • Feb 2018
        • 1153
        i have had a ricoh toner box that told me it fit the copier i was working on. come to find out it wasn't the correct toner. maybe the box was miss labeled from factory? when i opened the door to replace the toner, it told me the correct part # for a new toner. when i ordered that it worked fine.
          • 8153
          Is one on the toners slightly proud compare to the other 3 ?
          • Gift
            • Mar 2011
            • 2459
            Btw. did he meant he changed the chip after cleaning it? This would indicate he's working with compatible stuff - In this case one might start with checking original Ricoh toner/chip.
            • TonerMunkeh
              Professional Moron
              • 3865
              Could also be the toner housing is broken. Lovely job.
              Hit it.
              • Oze
                Ricoh Fanboy
                • 1663
                Could also be the sub hopper.
                We've had the boxes saying (usually) that it's out of yellow toner and it turns out to be a twisted auger in the sub hopper assy.
                Crap job.
                • pasion1
                  • Nov 2020
                  • 15
                  Crap job.
                  It was solved by placing an original toner. Thank you
                  • UNICORNico
                    • May 2018
                    • 308
                    For adding information to the thread.
                    Some time ago we received a call from a customer (not maintenance) who had detection problems with toner.
                    - Toner not detected or poorly installed.
                    - SC code in the historical, chip read failure.
                    - The device would crash and not let work.
                    It turned out that the Non-Original toner (purchased from another seller) on the front of the cartridge that must face in the hopper, the guides / fins were larger, causing the cartridge to end up being pushed, unlike the original.
                    1a02289e_b1.jpg 32f8ba1f_b2.jpg (detail photos in original toner)
                    The test of shaving this area was done to test, which allowed the device to work normally. But it was the perfect excuse to justify buying toner from us instead of a third xD
                    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
