Ricoh mp 5000 - copy/scan extreme light - in print are ok
  • luca72
    • Oct 2017
    • 1792
    Hi, guys, first to pass at replace the image sensor, I would like to ask this:
    I have this mp 5000 (521k) and pcdu kit (30k) in a school, which prints quite well, but when it makes the copies they come out practically white, the client did not notice, but I did, I removed the auto density, and moved the cursor all to dark, and stored everything as default situation, and let's say that now they are acceptable, I tried to look in SM, for some SP, to adjust the scan density, but there are 20k, and in the description it is not clear very well, which is what interests me .... does anyone know that SP? .. I just have to darken the image in the sensor.
    "I'll be back"
  • MBZ6301
    • Aug 2016
    • 42
    Re: Ricoh mp 5000 - copy/scan extreme light - in print are ok
    You didn't mention if you cleaned the scanner mirrors. I hope you did though... On a lot of (usuallly) older black and whites they go really faint when covered in dust
    • luca72
      • Oct 2017
      • 1792
      yes, thank...its all cleaned from head, to feet, there is very too different from print density, and copy/scanned image, when the laser are dirty,it start to become light from a side, here its homogeneous, i suspect the image sensor defective, or at a lost, but i want first try with some scanner-SP's if work.
      p.s. i have 3 complete mp5000 retired, in our warehouse, for pick the image sensor unit
      "I'll be back"
        • 37653
        If you shine a laser pointer at a mirror. If you see a small dot the color of the pointer, that mirror is not clean. If enough filming builds up on the lamp reflectors, mirrors and lens, during POST the white reference will look like a shade of gray. The 5000 will adjust its gray scale to get it back to white. This lightens the entire grey scale for both copying and scanning. Light gray becomes white, medium gray becomes light gray, dark gray becomes medium gray and black becomes dark gray.
        • luca72
          • Oct 2017
          • 1792
          Hi Tim, i have clean the optic two time, its super clean.
          "I'll be back"
          • luca72
            • Oct 2017
            • 1792
            Hi Tim, i have clean the optic two time, its super clean...and the White bar under the glass its full white
            "I'll be back"
            • GIUBOSS
              • 1437
              Have you tried resetting the copier and scanner user mode settings?
              • MIGUELMARCHENA
                • Feb 2018
                • 197
                Hello good morning
                I would lower the laser and clean it super, because the same has happened to me, clear copy, full printing, but remember that the laser handles more resolution so it will come out better than the copy.
                in such a case to continue, it has also happened to me that I had to clean the ccd window and in this model if it allows it,
                It was dirty because it was a stationery store that overlooks the street and freight vehicles with acpm travel through it, which generates a lot of soot.
                I hope something serves my contribution.
                Cheers
                • dalewb74
                  • Feb 2018
                  • 1167
                  have never heard of this before, nor considered it. but it makes good sense. would you recommend one of the green lasers for testing this?
                    • 37653
                    I have been using the technique for decades, starting with fluid toner estats. What I used back then was a penlight with a very tight focused beam. Hard to find now a days. A clean first surface mirror would reflect a high enough % of the light beam that you cannot see it on the mirror. The more the film built up from the crap in the air, the more you can see an illuminated spot.
                    • luca72
                      • Oct 2017
                      • 1792
                      I understand, like a an old PlayStation 1 game, that the soldier use a cigarette Smoke to detect the invisible laser allarm beams in the path.....cool
                      "I'll be back"
                        • 37653
                        At one time when smoking was permitted just about everywhere, the filming on copier mirrors and platen glass often was from cigarette smoke.
                        • luca72
                          • Oct 2017
                          • 1792
                          Originally posted by MIGUELMARCHENA
                          Hello good morning
                          Cheers
                          hi, thanks, I'll try, but there is too much difference between the prints, and the copies, by prints I mean, counter, smc, config, the machine, it is not on the network, and used only as a copier
                          "I'll be back"
                          • luca72
                            • Oct 2017
                            • 1792
                            Hi, could be a good street...and also via sp801, and a firmware rewrite, i try
                            "I'll be back"
                            • luca72
                              • Oct 2017
                              • 1792
                              I remember, there were also operation panels with the forgotten lit cigarette on top ... LOL
                              "I'll be back"
