ricoh mp c3003 , problem .
  • tullio
    • Feb 2012
    • 268
    sheet removal. same problem. the sheet is not there.WhatsApp Image 2022-10-05 at 18.09.39.jpg already
    'happened?WhatsApp Image 2022-10-05 at 18.10.41.jpg thank you
    • 37357
    Re: ricoh mp c3003 , problem .
    J001 is quite often a defective door switch or a defective paper path sensor. If it has an external finisher, I would start with replacing the cover switches in the bridge unit.
    • luca72
      • Oct 2017
      • 1745
      Originally posted by tullio
      sheet removal. same problem. the sheet is not there.[ATTACH=CONFIG]54856[/ATTACH] already
      'happened?[ATTACH=CONFIG]54857[/ATTACH] thank you
      it also happened to me on mpc3003, try to replace the sensor wiring that goes from the machine to the PTR unit...and let us know
      "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
      • TonerMunkeh
        Professional Moron
        • 3865
        Look at the input checks, one of the sensors will be showing active causing the jam.
        Hit it.
