I have a machine ricoh MP4054 Sometimes when I press the start button of the machine for photocopying, it only scans, but the paper does not come out, that is, the paper does not feed from the tray, then when the machine is restarted, or if I open the front cover or the right side cover, then the copy is done, a, I formatted harddisk and cleared the memory but the problem is not resolved
Mp4054 machine only scan not print out
Re: Mp4054 machine only scan not print out
Or, it might be set for sort. Read the screen, what is it telling you?Comment
I have a machine ricoh MP4054 Sometimes when I press the start button of the machine for photocopying, it only scans, but the paper does not come out, that is, the paper does not feed from the tray, then when the machine is restarted, or if I open the front cover or the right side cover, then the copy is done, a, I formatted harddisk and cleared the memory but the problem is not resolved"Enjoy every sandwich."
-- Warren ZevonComment
I know what your problem is. You need to order this part... it can be a little expensive but the good news is you can install it yourself. It is called an "office assistant" (in the old days it was referred to as a "secretary"). It helps one manage the tasks which are just too difficult for some people in a modern office environment. Good luck.Comment
Thanks for the laugh!Comment
