Mp4054 machine only scan not print out
  • babu
    • Apr 2018
    • 19
    I have a machine ricoh MP4054 Sometimes when I press the start button of the machine for photocopying, it only scans, but the paper does not come out, that is, the paper does not feed from the tray, then when the machine is restarted, or if I open the front cover or the right side cover, then the copy is done, a, I formatted harddisk and cleared the memory but the problem is not resolved
    • 37052
    Re: Mp4054 machine only scan not print out
    Check that it is not set to 2 sided and waiting for the second original.
    • sandmanmac
      • 3973
      100%
      • anothertech
        • 1757
        Or, it might be set for sort. Read the screen, what is it telling you?
        • babu
          • Apr 2018
          • 19
          Yes the machine want to next original and press #, i also press # and start key but no print Out
          • DRichard
            • May 2008
            • 482
            I know what your problem is. You need to order this part... it can be a little expensive but the good news is you can install it yourself. It is called an "office assistant" (in the old days it was referred to as a "secretary"). It helps one manage the tasks which are just too difficult for some people in a modern office environment. Good luck.
            "Enjoy every sandwich."
            -- Warren Zevon
            • anothertech
              • 1757
              In New York State the position is called Administrative Assistant. A good AA can save us getting a lot of unnecessary calls.
                • 37052
                It said press #, not # and Enter.
                • sandmanmac
                  • 3973
                  Hahaha...I know what Babu is thinking about you....
                  Thanks for the laugh!
