MPC8002
  • drew007
    • May 2018
    • 21
    MPC8002
    Hi. 8002 won't let me in admin mode/sm/factory mode. can't open extended features on panel. can still see wim.
    tried the factory reset (./ + #). it just bleeps once and doesn't reboot.
    Any ideas ?
  • Ricoh-ono
    • 338
    Re: MPC8002
    Sometimes the screen will lock up, especially if there were storms in the area. Unplug the machine from the wall. Press the power button to discharge the power supply. Plug it back into the wall and see if it will boot up.
    Sent from my Pixel 4a using Tapatalk
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
    • Amoussou
      • Oct 2022
      • 6
      Re: MPC8002
      Hello I have problem with my Ricoh...
      Ricoh Pro c5100s SC 536-01
      I change the fans 15,16 and IOB bord,the ero is not go
      Any idea
      • rthonpm
        • Aug 2007
        • 2854
        Re: MPC8002
        Any idea
        Instead of pinning on someone else's post, just create your own... It's the basic courtesy of a forum site and is not that difficult.
        • GIUBOSS
          • 1435
          Re: MPC8002
          Any ideas ?
          format the hdd and update the fw
          • copier tech
            • 8144
            Re: MPC8002
            Any ideas ?
            What happens when you try logging into admin & service mode ?
            Try restarting the machine with the LAN cables disconnected then try logging it again after waiting 5 mins etc.
            If this fails try updating ALL the firmware.
