DF scanning failed - MP 301
  • UNICORNico
    • May 2018
    • 308
    Dear fellow technicians.
    We have a strange incident on the device 'MP 301'.
    In which during the use of the original feeder (DF), when scanning the 2nd side of the folio, a line is generated in the direction of scanning, but never on the 1st side. We have carried out tests with the part of the explorer or exposure glass and when the optical cart moves, either the copy or the scan does NOT generate any scratches.
    202211101710.pdf - Google Drive
    The sample that we provide, the page does not have text on the 1st side, but on the 2nd to show the detail. We already confirmed that the optics have been checked and I have been carefully checked, trying to thoroughly check each mirror and despite the cleaning we found nothing.
    Obviously this failure is striking, because the folio goes through the same part 2 times during the use of the DF, and we do not see sense in this defect.
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • 37628
    Re: DF scanning failed - MP 301
    Blank Page Detect might be turned on. Try scanning something with printing on both sides.
    Clean the slit glass with an alcohol prep.
    • Gift
      • Mar 2011
      • 2459
      That's really odd - so it's only happen on duplex/2nd side in DF mode despite that this machine doesn't have a dual scanner?
      I'd still try the usual stuff, like cleaning the optics and especially the CCD element with compressed air (well, szart with compressed air and then clean the mirrors/glasses^^).
      It's also possible that the scanner frame or DF is bent so you can run another test wile lifting the front/left corner of the scanner housing a little.
      Taking a look at all scanner and DF related SP values might also make sense or compare the non default page with a working machine.
      • KeviM
        • Oct 2019
        • 327
        Definitely looks like optics. I'd definitely try what the other techs said
        Also if that doesn't work try to swap that scanner assembly
        Also as a VERY LAST RESORT AND AT YOUR OWN RISK and I do MEAN that you WILL BE TAKING A VERY BIG RISK, you can try spraying the CCD and optics with Mass airflow sensor cleaner. It might help but you will be taking a big chance because it might also not work or end up damaging the scanner unit and CCD
        All the best friend
        • anothertech
          • 1771
          No reason to use anything other than isopropyl alcohol or water. Look down into the optics with a flashlight, you should be able to see the problem.
            • 37628
            I like alcohol prep pads because a zip closure bag of them do not weigh as much as an 8oz bottle of alcohol and take up less space in the tool case. I have found that water does not always adhesive residue and ink from some fluid ink pens. For mirrors and lamp reflectors I like to use Chicopee Stretch and Dust cloths.
            • Gift
              • Mar 2011
              • 2459
              Doesn't the chicopee cloths contain some sort of wax (the orange ones)? Many years ago I tried to clean my glasses with these orange cloth and learned that lesson LOL
              We mostly use window cleaner or isopropanol.
              • UNICORNico
                • May 2018
                • 308
                Something similar has been indicated to us from Ricoh Ricess.
                Although we are surprised that they tell us that the corner that is in the air, we pull it up (they recommended that we try it for the 2nd time), in case that part of the explorer was deformed.
                We recently went through the client to test the latter (that the browser is deformed), but no change was detected in this failure.
                On a next visit we will test the topic of scanner configuration. But there must be something in the optics because in our view the defect seems to us to appreciate a slight distortion in the image where it scratches.
                  • 37628
                  what i would do was drag one across the mirrors. The wax would attract any dust or toner. The wax does not transfer to a surface unless you press it hard against the surface and doing that with first surface mirrors usually results in scratching the reflective surface.
                  • luca72
                    • Oct 2017
                    • 1792
                    you see a strong distortion in the image by enlarging it, two things come to mind, which have happened to me.
                    1) the internal screws of the hinge of the rdf are starting to unscrew, try to press the rdf with your hand on it to see if anything changes
                    2) the document dragging reverse mechanism of the rdf, does not work well, I suggest you remove the upper plastic cover of the rdf, and observe/check very carefully the reverse mechanism which is at the front (direction of te) while he is working, to see what happens, I remember that there was something that once messed me up
                    one thing, but the dark line, its always in the exact same spot? or does it move?
                    "I'll be back"
                    • copier tech
                      • 8220
                      Do you can the line if you copy from the main glass duplex or is it only when using the DF.
                      I see you have stated you carefully cleaned all optics etc so I would suggest that.
                      • UNICORNico
                        • May 2018
                        • 308
                        Only in the DF.
                        On a next visit, we will check the suggestion. I may not have noticed any detail, we have not come to appreciate anything unusual in the return of the paper. We will try to be more meticulous. (Although it was a theory that at first we had discarded)
                        The line is not nine, it is always in the same exact position.
                        • UNICORNico
                          • May 2018
                          • 308
                          Only in the DF.
                          I wanted to say that the black line DOES NOT MOVE, I do not know why I put "nine", failure to type or subconscious xD haha
                            • 37628
                            One time that I encountered a similar problem the cause was that to eliminate wasting paper someone had loaded used paper that was blank other than the lines on the back side.
                            • UNICORNico
                              • May 2018
                              • 308
                              Unfortunately it is not that simple. The paper is new, just opened from his package, I still have the visit pending, luckily the client does not seem too impatient, for this failure.
