Ricoh MPC PQ Issues
  • adamcopiercali
    • Aug 2012
    • 88
    Ricoh MPC PQ Issues
    Hoping for some guidance. Filling in for a colleague, working on a MPC 5503. Not too familiar with these models. Replaced a PCU for PQ issues, however unit is still having issues. Attached are samples. Trying to determine if this is a transfer belt cleaning issue? Or fuser? Thanks for any input. MPC 5503 Sample Print.jpg
  • GIUBOSS
    • 1436
    Re: Ricoh MPC PQ Issues
    You have a problem with black, if you have replaced the original black pcu it is very likely that the developer is also out of stock. It doesn't seem like a fusion problem to me, also check the transfer belt if it is cleaned by pulling it out of the machine.
    • sandmanmac
      • 3981
      What was the initial reason for replacing the drum? The same CQ issue?
      And why have you dumped the initial thread you started last about your issues with this machine just last week?
      Ricoh MPC5503 (K) Dryum & Developer Replacement
      • adamcopiercali
        • Aug 2012
        • 88
        Sorry about that. Yes, same CQ issue and the black drum was way overdue for replacement.
          • 37532
          What else was way over due for replacement? Maybe the ITB unit, ITB cleaning unit, or the ITB. How about going into Printer SP and printing the color test page. In can tell us a lot more than a mostly B/W print does.
          • MIKON
            • Jul 2015
            • 188
            Fuser
            • copier tech
              • 8172
              Hoping for some guidance. Filling in for a colleague, working on a MPC 5503. Not too familiar with these models. Replaced a PCU for PQ issues, however unit is still having issues. Attached are samples. Trying to determine if this is a transfer belt cleaning issue? Or fuser? Thanks for any input. [ATTACH=CONFIG]56240[/ATTACH]
              That is the fuser causing this copy quality issue.
              Replace the fuser sleeve.
              • Gift
                • Mar 2011
                • 2459
                Before replacing the fuser I'd inspect the ITB + ITB cleaning unit
