Many problems with Aficio MP C305 SPF
  • hsnslh
    • Feb 2021
    • 10
    Hello,
    I have a problem updating System/Copy: E44 when reading from SD card.
    Now I get stuck on "Waiting for firmware update data..." message every time I restart the machine, even if I don't insert the SD card into the slot.
    I had some errors before the update, like address book error, authentication module and websys.mod, home web page shows "404 Not Found" (and still having them)
    Now I can't access SP mode (beeps every time I try)
    The printer is in an unused state.
    I read in some threads that I need to change the NVRAM. I have no idea where can I find them on the board, and how to proceed.
    If you have any idea, I appreciate your help.
    Thanks.
  • anothertech
    • 1771
    Re: Many problems with Aficio MP C305 SPF
    Boot the machine without the SD card, then
    Clear modes, 1,4,3 ,clear/stop, clear/stop, clear/stop, reboot
    • hsnslh
      • Feb 2021
      • 10
      Hello
      thank you for your reply
      I've already done this, it only clears the E44 error
      The update message appears again whenever I restart
      • anothertech
        • 1771
        Then download the System firmware again and put in on a different SD card. Try it again.
        • sandmanmac
          • 3981
          Apparently you refuse to give up until you've rendered it entirely unusable!
          Maybe you should start a 4th new thread about this!!
          Need a firmware for Aficio MP C305 SPF
          Stuck in Admin password setting
          • hsnslh
            • Feb 2021
            • 10
            Is there any problem about this ?
            • hsnslh
              • Feb 2021
              • 10
              Thank you for your reply
              Already done this but didn't work.
              • UNICORNico
                • May 2018
                • 308
                Originally posted by hsnslh
                Hello,
                Thanks.
                My intuition tells me that you turned off the device during the firmware update...
                Probably you got an error and you did not wait for the automatic restart that it usually does when it detects errors.
                I'm afraid you'll have to replace the NVRam.
                "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                • hsnslh
                  • Feb 2021
                  • 10
                  Hello and thank you for your reply
                  Can you tell me where the NvRam is located so that I can replace it
                  Best regards
                    • 37532
                    Read the damned service manual.
                    • Ales
                      • Oct 2013
                      • 14
                      Best regards
                      nvram are located on the controller board
                      • anothertech
                        • 1771
                        Best regards
                        If you have to ask, you shouldn't be working on this machine. There are so many pitfalls, no way you'll get through it.
                        • Zaxxon
                          • 608
                          Next question will be: where can I find the manual?
                          Please start you post with brand, model, problem.
                          • GIUBOSS
                            • 1436
                            part number : D1179590
                            NV-RAM
