change to 3.5" hdd ricoh
  • aviso66
    • Dec 2012
    • 202
    Hi, can i use a 3.5 inch hdd for a copier hdd instead of 3.5inch?
    • 37652
    Re: change to 3.5" hdd ricoh
    Did you proof read your post? a 3.5 for a 3.5???????
    • aviso66
      • Dec 2012
      • 202
      oops sorry. there's a lot of stuff going on in my mind....going too fast....
      its 2.5 to 3.5 haha
        • 37652
        I would say that if the connections are the same and you have a means to securely mount it, go for it. The biggest concern would be current draw.
        • sandmanmac
          • 3990
          I doubt it will work, but at a minimum it'll be difficult to secure.
          But my question is why would you even want to bother?
          Used HDD's are a dime a dozen (so to speak).
          • copier tech
            • 8237
            The question usually asked is can I swap the HDD with an SSD.
            • anothertech
              • 1771
              I think it's about time for Ricoh to start equipping all new machines with SSD's, and come out with a part number of an acceptable SSD retrofit drive for existing machines.
              • rthonpm
                • Aug 2007
                • 2860
                The main reason they likely haven't is the fact that write intensive SSD's are still fairly expensive as its generally a server SSD feature. With MFP's writing and deleting data frequently, the drives would degrade much faster than spinning rust, especially with consumer level drives.
                • Gift
                  • Mar 2011
                  • 2459
                  I don't think Ricoh will oficially offer this because in this case the data overwrite feature won't do it's job anymore properly since the wear levelling tech inside the SSD doesn't let you adress specific memory cells for overwriting. Instead - if enabled - this feature triggers a lot of random writes reducing the lifespan of the SSD.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    If Kyocera can use NVME SSD...then why can't other manufacturers?
                    • fbkhan3
                      • May 2012
                      • 421
                      Hi,
                      I swapped it with 1TB SSD 3 years ago in one of MP 6503 and still no issues, customer has large print and scan volume on this device.
                      Regard's
                      • Gift
                        • Mar 2011
                        • 2459
                        KM does it, too - with some probs at the beginning but currently no issues. Of course the nvme/ssd should be of a decent quality.
                        • anothertech
                          • 1771
                          Originally posted by fbkhan3
                          Hi,
                          Regard's
                          Did it speed up bootup time or print spooling?
                          • fbkhan3
                            • May 2012
                            • 421
                            Thanks for pointing it it out,
                            To be very honest i was in restricted area and tried that as an only available option that time and thing is working without a glitch also have SLNX installed on that device, didn't notice and compare if that has an impact on boot time and print spooling.
                            But i will surely note the details upon next visit.
                            Regard's
