Ricoh MP C2003 noise
  • menosmola
    • Apr 2014
    • 95
    Hello, I have a client with a Ricoh mpc2003, he sends me this video. Can someone identify from the sound what kind of problem the machine has? The machine seems to work perfectly. I think it's the transfer belt...
    https://dai.ly/k1C1fl6nAkTIC2yKpSA
  • Zeldaman
    • Mar 2011
    • 946
    Re: Ricoh MP C2003 noise
    Hi there!
    Normaly this noise comes a) from the fuser, or b) from wornout paperrollers in one of the cassettes.
    Greetings...
    • copier tech
      • 8174
      That's vibration coming from the transfer cleaning blade.
      I'd replace the transfer cleaning unit if you have one.
      • luca72
        • Oct 2017
        • 1784
        use SP "output check" to find the noise unit, if you want test the fuser unit movement, remove the waste toner bottle first, for not burn the sleeve!
        "I'll be back"
        • menosmola
          • Apr 2014
          • 95
          Forgot to post the solution... To whom it may concern, the noise was caused by the gears of the fusing unit.
