MP C3003 WIM and SMB issues. Tried everything.
    • 37558
    #16
    Re: MP C3003 WIM and SMB issues. Tried everything.
    Originally posted by steele
    I know what Wireshark is. I have been a computer network engineer for 20 years.
    Novice. I have been working on them since Olivetti first brought out the M20 built around the Zilog Z8000 CPU in 1982. Later in 1983 they introduced the M24 which was an IBM clone built my Corona Data Systems.
    • Elmo
      • Feb 2010
      • 541
      #17
      possibly corrupt NV ram are you able to check settings against the birth certificate or another machine
      I Used To Live To Fix Things Now i Fix Things To Live
      • PrintWhisperer
        • Feb 2018
        • 473
        #18
        It does seem like most of the basic protocol session set-up works from the fact that a file is created at all.
        Conversion from .tmp file to final file name schema will be in the latter part of the SMB session and any problems with it could show-up. (non-unique name schema)
        The Wireshark capture will be accurate evidence you need to escalate the issue if you suspect a firmware/API problem and rule out the basic 'suspect' network issues that will be suggested as a fix. However stick to one environment for reporting and testing or the results are viewed as 'not definitive' (anecdotal)
        It will also verify the ACTUAL SMB version which is negotiated with the server BUT only if done onsite.
        SMB version negotiation is determined by the "server" or computer sharing the file. The MFP offers up all enabled versions (dialects) for the "server' to determine.
        The firmware could work fine for one dialect but not for another, but only the network session will tell the tale.
        "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        • dave w
          • Jun 2015
          • 230
          #19
          Best to connect a laptop directly onto the MFP and try the WIM and Scan to folder directly onto the laptop. my hunch is it will work.
          Goodluck Steele
          I also had the same issue
          IM C2500 - scan to folder = 0kb - its not the MFP
