mp c6004 secondary trans roller
  • digicor
    • Jul 2008
    • 1159
    My manual has this D2416212, but ive been reading its not the right one, does anyone have the correct part number for this? or is the D2416212 the correct part? manual has warning about the right one and wrong one but doesnt list prt nbs
    • 37532
    Re: mp c6004 secondary trans roller
    Is it the PTR that is not the right one or the parts catalog? There are separate parts catalogs for the C3004/C3504 and the C4504/C5504/C6004. The number for the PTR listed in both is the same, D2416212.
    • anothertech
      • 1771
      The new parts manual has the updated part number, D0BQ6212
      You can use either part number, same roller.
        • 37532
        D0BQ, that would be the new number introduced with the IM C series.
        • davel
          • Oct 2011
          • 1107
          If machine is printing on oversized paper the PTR is different.
          • digicor
            • Jul 2008
            • 1159
            Thank you
            • Gift
              • Mar 2011
              • 2459
              Yeah I think that one is/was available as an "option" and was cheaper than the regular spare part IIRC.
              • Lebulck
                • Jul 2020
                • 2
                I think you're talking about the "Imageable Area Extension Unit Type M19", I forget the exact pn.
                If you use that one you should not forget to set SP2-400-001(Paper Transfer Roller Settings Width of Paper Transfer Roller) to "1".
                • Gift
                  • Mar 2011
                  • 2459
                  Yes that's true - if you forget the SP you can't set up wider formats.
