MP402, SC302 code
  • copycart
    • May 2009
    • 97
    MP402, SC302 code
    The manual does not offer a lot. When Ricoh says power pack, are they referring to the power supply board
  • dalewb74
    • Feb 2018
    • 1153
    Re: MP402, SC302 code
    service manual that i just downloaded from ricoh. it tells the issue and the fix for it..
    • anothertech
      • 1770
      SC No. Level Error Name/Error Condition/Major Cause/SolutionSC302 D High voltage output error: Charge unit /Development unitThis SC is issued if the BiCU detects a short in the power pack 10 times consecutively.Short circuit (-)• Replace the controller board.• Check the connector connection.
      So this says high voltage output error, maybe new drum? if not, then check high voltage power supply area or connections/bias plates in between drum and HV power supply.
