MPC5503 with recurring SC544-02
  • mrwho
    Major Asshole!
    • 4299
    [Error Code] MPC5503 with recurring SC544-02
    Mascan42
    Ibid
  • Zeldaman
    • Mar 2011
    • 946
    • brodiescomics
      • Mar 2012
      • 31
      Re: MPC5503 with recurring SC544-02
      I was thinking the same. Is it on a surge protector? If so, it may be bad. If not, you may try one.
        • 37649
        Surge protectors don't help if the problem is sags, slow changes or floating ground. Floating grounds can kill.
        I have had bad grounds cause Lanier 1200 word processors to erase files on floppy disks. It was a portable building on a military base. The outlet grounds were tied to the building frame. Regional rep came up from LA with a Dranetz 3 port monitor. Hooked it up and started getting multiple hits a minute to include hot to ground and neutral to ground. Base engineers came out the next day, sunk a 12 foot ground rod into sandy soil, tied the building ground to the ground rod and the problem went away.
        • brodiescomics
          • Mar 2012
          • 31
          Surge protectors are a useful tool in diagnosing power issues. Which is a possibility in this particular situation.
          • mrwho
            Major Asshole!
            • 4299
            The thought crossed my mind, but that machine went in to replace a MPC6000 - and that's a beast of a machine and, in my opinion, much more sensitive to those kind of things.
            I also thought "hey, maybe they're trying to use the MPC6000 at the same time, and that's a power hungry beast", but no - the customer has had the machine powered off for a while, since it's got no contract.
            I went there today and replaced the PSU. Let's see how it goes.
            Mascan42
            Ibid
            • dalewb74
              • Feb 2018
              • 1167
              that is only if it was designed for copiers. such as innovolt or etc... if it is a cheap you know what from the store then no..... not on a laser copier/printer. if you put a cheap surge protector on a laser machine. then you are just begging for issues. the cheap ones from the local store are not rated to handle the power load. just my 2 cents on that one...
                • 37649
                The only things from the trouble shooting guide for SC544-02 that you haven't listed is the PSU and the BCU. Also check the wiring harness for bad/loose connections from the Non Contact thermistors and the thermopiles to the BCU and BCU to the PSU.
                • mrwho
                  Major Asshole!
                  • 4299
                  It didn't go well.
                  Boss decided to loan the customer another equipment and bring that back to the shop so it can be analised.
                  Will keep you posted.
                  Mascan42
                  Ibid
                  • Thirdp3rs0n
                    • Sep 2015
                    • 3
                    It didn't go well.
                    Oooh Hey, how did we get on with this? I assume it didn't fault again onsite and didn't fault again in the workshop.
                    Nate
