Mp c3504 copy registration issue
  • Marwanalhajbi
    • Jul 2018
    • 72
    greetings everyone,
    after clear memory i 'm having an issue with copy not accurate and there is yellow shadow on copied paper showed in the attachment.
    i have inserted all sp modes in the paper with machine,i made registration and calibration for printer and copier,also force line adjustment,but no results,
    any suggestion please?20230608111018556.pdf
  • DRichard
    • May 2008
    • 482
    Re: Mp c3504 copy registration issue
    Originally posted by Marwanalhajbi
    greetings everyone,
    any suggestion please?[ATTACH]58501[/ATTACH]
    "Clear memory"...not a good idea. (As you now know.)
    Pull out the copier's factory birth certificate and go into the Service Mode and start entering the factory settings listed on it. Lesson learned?
    "Enjoy every sandwich."
    -- Warren Zevon
    • Marwanalhajbi
      • Jul 2018
      • 72
      what do you mean by copier's factory birth certificate?do you main which come with the printer ,i already acheieved all sittings from there.
      about the lesson.offfffffff course ,but i had no clue what to do with scan to email,the customer had a different technician was chaning some of sp modes so i had to .
      • GIUBOSS
        • 1410
        You had to first inform yourself (also here in CTN) about memory cleaning, you had to print that certificate first. How did you do the color alignment?
        • Marwanalhajbi
          • Jul 2018
          • 72
          Mode a then b then c then d
          after that registration and calibration printer the copier,
            • 37448
            More often than not clearing engine memory the registration will be too far off for that to correct it. FYI, memory All Clear will clear engine memory. If you do not have the Birth Certificate, a printout that of all final factory settings made ro adjust a machine that is sent with every new machine, or a recent Non Default printout you now have a few hours of manual adjustments to do in order to get dot positions and mirror tilts to where automatic adjustments will be able to pull registration back in.
            • GIUBOSS
              • 1410
              an attempt is to clean the ID sensors, update the fw and repeat the forced alignment
              • luca72
                • Oct 2017
                • 1762
                greetings everyone,
                you machine it out registration, first to attempt to apply any thing of reset, i suggest to you of check, the free rotation of yellow pcdu, that looking your attachment seem the l'only out registration, try to rotate with hand, and check if its more hard respect to others
                "I'll be back"
                • Gift
                  • Mar 2011
                  • 2459
                  Try and run c first ~20 times, then b and finally a
                  Make shure all SP parameters from the factory sheet has been entered correctly.
                    • 37448
                    Have you ever read the portion of the service manual that describes Forced Line Position? Mode C is a rough adjustment. It is always ran before either Mode A or Mode B. Mode B is the fine adjustment. Mode A executes Mode B twice. On models that have Mode D, is does both rough and fine adjustment.
                    • dalewb74
                      • Feb 2018
                      • 1143
                      if you have a scan to email issue why would you even do a memory clear? why wouldn't you just go into the webpage for the copier? unless there was an admin password you are trying to bypass? i wouldn't think you would need into the sc modes to make changes to the scan settings.
