RICOH MP C2011
  • Khumz
    • Feb 2020
    • 63
    RICOH MP C2011
    I have Ricoh MP C2011 which does not load black toner. Even if i run forced toner supply still it does not load and toner bottle is not turning. I checked voltage into the hopper none is coming through. With magenta, cyan and yellow i do get voltage as toner bottles turn when i activate forced toner supply. Any suggestions and ideas please.
    Again it does not show black toner on the display panel, only magenta, cyan and yellow appear.
  • GIUBOSS
    • 1436
    Re: RICOH MP C2011
    OEM toners? What does the MFP indicate, loading toner? Add toner? Try cleaning (not direct vacuum) the sensor on the machine.
      • 37533
      Re: RICOH MP C2011
      More often than not the problem is either the toner bottle tray, the toner bottle drive or the wrong toner bottle.
      • copier tech
        • 8176
        Re: RICOH MP C2011
        I have seen the auger in the hopper break causing issues like this.
        Replace the K hopper part number: D0BQ3240
        • anothertech
          • 1771
          Re: RICOH MP C2011
          The new part number for the modified hopper is D0BQ3242
          • copier tech
            • 8176
            Re: RICOH MP C2011
            Thanks. They do send out the modified one even if you order the old type.
            • Khumz
              • Feb 2020
              • 63
              Re: RICOH MP C2011
              Black toner motor is not turning when i execute forced toner supply. But the motor itself it is fine because i swapped it around with one driving cyan toner bottle. When i trace wiring back it is all controlled by PWB-D1495140 board. Not sure if the board is failing or i m missing something somewhere.
              • GIUBOSS
                • 1436
                Re: RICOH MP C2011
                Before replacing the pcb try doing a memory wipe (first you need the birth certificate) and the FW update.
