RICOH MPC305 - Paper jam from computer
  • Fremalea
    • Jun 2019
    • 42
    Hello everyone Sorry for the poor google translation.
    I have a Ricoh mpc305spf which brings me rather satisfaction.
    But I have a strange problem. When I launch a print from one of my computers, I have a "paper jam", Double-sided only.
    I tried from several computers, same problem.
    I was thinking of a problem coming from the printer, but I noticed that when I print from my phone with the Ricoh application, no problem !!
    Is it a driver problem? Thanks for your help
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: RICOH MPC305 - Paper jam from computer
    Sounds like a paper size problem, WSD port or Windows Class driver problem. How do you have the machine set up?
    Hit it.
    • luca72
      • Oct 2017
      • 1791
      look, I think the fact that it jams from the computer is just a coincidence, get yourself a can of air, and with the machine off, try blowing the reversing f/r sensor which is located, by opening the side door, at the top right, immediately above the fuser unit, with a light you should see it, it is a "U" optical sensor, with a plastic arm that activates or deactivates it, it will be full of dust, I don't think it is necessary to disassemble the fuser to clean it
      "I'll be back"
      • Fremalea
        • Jun 2019
        • 42
        thanks for your advices. I don't think it's a coincidence. I had the problem several times, and each time printing from the smartphone worked just fine.
        But I will clean this sensor, thank you!
        • Fremalea
          • Jun 2019
          • 42
          it's a standard PCL6 driver from ricoh
          • luca72
            • Oct 2017
            • 1791
            you will see that it is...ciao
            "I'll be back"
            • Gift
              • Mar 2011
              • 2459
              I know stupid question, but: Do you print duplex/2sided via smartphone?
              • dalewb74
                • Feb 2018
                • 1162
                ok it happens when you print, but does it also happen when you duplex copy as well?
                • copier tech
                  • 8191
                  Try a duplex / double side COPY then see if it jams ?
                    • 37557
                    Which PCL6 driver from Ricoh and what port is being used?
                    • Ricoh-ono
                      • 339
                      Could be a driver issue, but there were some early productions of the MP305 that had duplex jam issues. There was a clutch that would get oil on it from one of the bushings and it would fail.
                      Do what you can, with what you have, where you are. ~Theodore Roosevelt
                      • luca72
                        • Oct 2017
                        • 1791
                        so?....how did the story end?
                        "I'll be back"
                          • 37557
                          If he is using one of the "for Universal Print" drivers is hasn't ended well.
                          • luca72
                            • Oct 2017
                            • 1791
                            Ah...and jam the duplex?🤔
                            "I'll be back"
