Ricoh MP C401
  • luca72
    • Oct 2017
    • 1711
    #46
    Re: Ricoh MP C401
    Originally posted by pinkyman
    thank you guys for your attention .... i did firmware update and it done very well .. but everything as it is .. i still can't enter SP mood by Y 806782 C and still no interface settings no NC no USB ..
    i want you to notice that cable in the pic i pointed on it in the pic there is no socket for it .. maybe it is do something !!!!
    Yellow+806182+(c)!!!...not 782!!!..zio cane!!..LOL...for the nic, and the other...I'll explain it to you tomorrow, now I'm about to go to sleep, if not, tomorrow they'll have to pull me up with a winch...LOL
    "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
    • pinkyman
      • Jun 2022
      • 33
      #47
      Re: Ricoh MP C401
      Looking at illustration d191b0056 in the service manual for replacing the IPU, that portion of the harness is supposed to go above the IPU and to something under either the IPU or the Controller. You may need to lift the IPU and controller and look for where it goes. Ricoh used to be real good at putting at least one connector on the bottom of at least one PCB.
      can you send me service manual ?
      • RicohBoomer
        • May 2022
        • 40
        #48
        Re: Ricoh MP C401
        The only options available to you seem to be to either read the changed SP Code via an EEPROM reader as described in this old thread.
        Finding previous tech SP access code
        Or order a new set of NVRAM.
        Changing the default SP code is a really risky move. If a company or tech wants to keep unauthorized people from accessing the SP then they can just use the Service Lock in Admin tools instead.
        That also properly locks out factory.
        • luca72
          • Oct 2017
          • 1711
          #49
          Re: Ricoh MP C401
          that cable is for the optional meter,(see attachment) it's not connected to anything, it usually hangs high, just you made it go another route, instead to activate the NIC, you need to do sp 5-985-001 to 1, instead sp 5-985-002 to 1 for enable usb. and restart the machine to apply the effect
          • pinkyman
            • Jun 2022
            • 33
            #50
            Re: Ricoh MP C401
            bro ... i can't enter sp mood to do 5-985-001 it's locked even after do firmware update
            • luca72
              • Oct 2017
              • 1711
              #51
              Re: Ricoh MP C401
              At this point i suspect, the nv-ram or controller its bad, at 99% of case nobody change the sp service enter code....the last attemp that you can try, without spend Money, its put other nv-ram, from another machine ...the fact of change the sp enter code its very remote possibility...personaly, i never encounter this in over 35 years of work
                • 37056
                #52
                Re: Ricoh MP C401
                It sounds like Service Mode Lock is ON. Restricting a Customer Engineer Operation
                You need to login at the control panel as the machine Administrator. Logging in Using the Control Panel
                If you do not get the login button to login as Administrator then you may need to configure Administrator Authentication Configuring Administrator Authentication
                There is one other Administrator not listed and that is Supervisor. Supervisor has one and only one function, administrating the credentials of all the Administrators.
                • RicohBoomer
                  • May 2022
                  • 40
                  #53
                  Re: Ricoh MP C401
                  I did some local tests(Was an IM C3500 but I don't think there is a difference) with Service Mode Lock because I figured that could be the case, but if that is switched ON then you can't enter Factory SP either.
                  So it shouldn't be that but it doesn't hurt to check it.
                  • pinkyman
                    • Jun 2022
                    • 33
                    #54
                    Re: Ricoh MP C401
                    I tried to login and I used users names and passwords that in the attachment but no one works
                    • luca72
                      • Oct 2017
                      • 1711
                      #55
                      Re: Ricoh MP C401
                      Slimslob, Says to you, to login with "supervisor" account, with blank password, and go to reset the admin password...at login, digit supervisor and leave blank the password field....this should have happened automatically, by inverting the nv-ram between them, (as I suggested at the beginning) this trick probably doesn't work on the 301 series....note well!!.. the only function of supervisor user, its the possibility of reset the admin 's password, and nothing of else!...serve only for this...keep presente this.
                      • pinkyman
                        • Jun 2022
                        • 33
                        #56
                        Re: Ricoh MP C401
                        • luca72
                          • Oct 2017
                          • 1711
                          #57
                          Re: Ricoh MP C401
                          try "supervisor" with password "supervisor".
