Ricoh MP C401
  • pinkyman
    • Jun 2022
    • 33
    Ricoh MP C401
    Good evening
    I've Ricoh MP C401 color mp printer and I want to download Firmware of this machine .. I can't download it and how could i do it .. I can't retested in Ricoh Octopus .. how could i do it ?
    I need help I need the firmware file to load it by SD Card
  • luca72
    • Oct 2017
    • 1762
    Re: Ricoh MP C401
    Originally posted by pinkyman
    Good evening
    hi, type on google "ricoh firmware update tools", download it from ricoh, and run rfu.exe, follow the istruction, the machine must be connected via lan-cable, in your local network.
    "I'll be back"
    • pinkyman
      • Jun 2022
      • 33
      Re: Ricoh MP C401
      i have problem in this machine ... it working good in coping but USB and ethernet didn't work .. it also didn't enter service mood by Y 806182 C .. it only work if i use Y 143 C .. so i want to use a Firmware by SD Card maybe work
      • ridgemill
        • Sep 2017
        • 189
        Re: Ricoh MP C401
        Firmware won't fix this, either you have enabled IEEE802 security settings and disabled USB type B access.
        Or, you have a broken network port. (USB type B is usually disabled by default)
          • 37447
          Re: Ricoh MP C401
          Sounds like you are entering Factory SP mode. Most likely someone has changed the 6 digit SP mode access. A common change is ABCABC where ABC is the old 3 digit code. See if while in Factory SP Mode you can access the SP setting to change the 6 digit access code. Also see if you can access SP 5985. Most like on board NIC and USB are disabled there.
          • pinkyman
            • Jun 2022
            • 33
            Re: Ricoh MP C401
            I can't enter SP Mood .. the only way i can use it Y 143 C and I can't find SP 5985 on it .
              • 37447
              Re: Ricoh MP C401
              Can you login to User Tools as Admin? If so, check to see if IEEE 802.11 is enabled in the interface settings. It is used for a couple of things. To enable Ricoh's overpriced worthless POS WiFi interface option and for some high end network authentication protocols. Either way it will disable the wired network or in the case of authentication require proper authentication with the network server.
              • pinkyman
                • Jun 2022
                • 33
                Re: Ricoh MP C401
                where could i find the interface settings .. can i find it if i login by Y 143 C ??
                  • 37447
                  Re: Ricoh MP C401
                  User tools, not SP.
                  • pinkyman
                    • Jun 2022
                    • 33
                    Re: Ricoh MP C401
                    User tools, not SP.
                    no interface settings in user tools
                      • 37447
                      Re: Ricoh MP C401
                      Someone has changed something. You need to request a regional support engineer visit.
                      • copier tech
                        • 8138
                        Re: Ricoh MP C401
                        Log in as admin & go to administrator tools tap most likely its been disabled there.
                        • pinkyman
                          • Jun 2022
                          • 33
                          Re: Ricoh MP C401
                          login button didn't work i mean didn't do any action just peep only
                          • luca72
                            • Oct 2017
                            • 1762
                            Re: Ricoh MP C401
                            At this point you not have way, Reverse It the nv-ram, and reset everything...and activate It the nic via sp.
                            "I'll be back"
                            • luca72
                              • Oct 2017
                              • 1762
                              Re: Ricoh MP C401
                              At this point you not have way, invert the nv-ram's, and reset everything...and activate It the nic via SP
                              "I'll be back"
