Ricoh MP C401
Re: Ricoh MP C401
Looking at illustration d191b0056 in the service manual for replacing the IPU, that portion of the harness is supposed to go above the IPU and to something under either the IPU or the Controller. You may need to lift the IPU and controller and look for where it goes. Ricoh used to be real good at putting at least one connector on the bottom of at least one PCB.Comment
Re: Ricoh MP C401
The only options available to you seem to be to either read the changed SP Code via an EEPROM reader as described in this old thread.
Finding previous tech SP access code
Or order a new set of NVRAM.
Changing the default SP code is a really risky move. If a company or tech wants to keep unauthorized people from accessing the SP then they can just use the Service Lock in Admin tools instead.
That also properly locks out factory.Comment
Re: Ricoh MP C401
thank you guys for your attention .... i did firmware update and it done very well .. but everything as it is .. i still can't enter SP mood by Y 806782 C and still no interface settings no NC no USB ..
i want you to notice that cable in the pic i pointed on it in the pic there is no socket for it .. maybe it is do something !!!!Attached Files"loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)Comment
Re: Ricoh MP C401
that cable is for the optional meter,(see attachment) it's not connected to anything, it usually hangs high, just you made it go another route, instead to activate the NIC, you need to do sp 5-985-001 to 1, instead sp 5-985-002 to 1 for enable usb. and restart the machine to apply the effectComment
Re: Ricoh MP C401
At this point i suspect, the nv-ram or controller its bad, at 99% of case nobody change the sp service enter code....the last attemp that you can try, without spend Money, its put other nv-ram, from another machine ...the fact of change the sp enter code its very remote possibility...personaly, i never encounter this in over 35 years of work"loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)Comment
Re: Ricoh MP C401
You need to login at the control panel as the machine Administrator. Logging in Using the Control Panel
If you do not get the login button to login as Administrator then you may need to configure Administrator Authentication Configuring Administrator Authentication
There is one other Administrator not listed and that is Supervisor. Supervisor has one and only one function, administrating the credentials of all the Administrators.Comment
Re: Ricoh MP C401
It sounds like Service Mode Lock is ON. Restricting a Customer Engineer Operation
So it shouldn't be that but it doesn't hurt to check it.Comment
Re: Ricoh MP C401
There is one other Administrator not listed and that is Supervisor. Supervisor has one and only one function, administrating the credentials of all the Administrators.Attached FilesComment
Re: Ricoh MP C401
Slimslob, Says to you, to login with "supervisor" account, with blank password, and go to reset the admin password...at login, digit supervisor and leave blank the password field....this should have happened automatically, by inverting the nv-ram between them, (as I suggested at the beginning) this trick probably doesn't work on the 301 series....note well!!.. the only function of supervisor user, its the possibility of reset the admin 's password, and nothing of else!...serve only for this...keep presente this.Last edited by luca72; 07-15-2023, 03:23 AM."loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)Comment
Re: Ricoh MP C401
Slimslob, Says to you, to login with "supervisor" account, with blank password, and go to reset the admin password...at login, digit supervisor and leave blank the password field....this should have happened automatically, by inverting the nv-ram between them, (as I suggested at the beginning) this trick probably doesn't work on the 301 series....note well!!.. the only function of supervisor user, its the possibility of reset the admin 's password, and nothing of else!...serve only for this...keep presente this.Attached FilesComment
