MP501 quirk
  • tonerhead
    • Sep 2009
    • 582
    MP501 quirk
    I need a Ricoh/Kyocera god on this one. I thought I knew practically everything about Ricohs. The mfp has 2 additional paper trays for a total of 3 trays. All are set to bond, plain paper, and autoselect and duplex is turned on for each. Here is the glitch. When tray 1 runs out of paper it will not go to tray 2 automatically. It just stops in all modes. Same goes for tray 1 to 3 and 2 to 3. It just stops doing what it is doing and asks for paper in tray 1. At idle though, you can select a paper tray in copy and print modes as long as there is paper in tray 1.
    I guess I do not have another mp501 with additional trays to check for the same. First thing I thought was firmware, did that with no joy. I am guessing it is something in sp mode that got tweaked, couldn't find anything though. Any copier gods out there wanting to take this one on?
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: MP501 quirk
    Which driver are you using, and how is it set up?
    A screenshot would be nice.
    • GIUBOSS
      • 1433
      Re: MP501 quirk
      read here :
      MP 501SPF/MP 601SPF download page
      search in system, paper tray setting, tray switching
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Re: MP501 quirk
        Originally posted by GIUBOSS
        read here :
        Very true, but driver settings can override that.
        Is the issue with copying, printing, or both?
        If it's just with printing, it's likely a driver issue.
        If it's for both, it's more likely a machine tray switching setting issue.
        • DRichard
          • May 2008
          • 482
          Re: MP501 quirk
          ...or something like paper type mismatch on particular/specific jobs (?)
          "Enjoy every sandwich."
          -- Warren Zevon
            • 37481
            Re: MP501 quirk
            Is Auto Continue turned ON? If not turn it on and see if that takes care of the problem.
            Check for damaged connector and/or connector bracket between the 502 and the first add on tray. Also between the 2 add on trays. I have had them get damaged when there is a slight misalignment during assembly.
            • tonerhead
              • Sep 2009
              • 582
              Re: MP501 quirk
              Thanks for the answers. This problem happens in all modes copy/print/fax. I have a part ordered for the dreaded tray one lift issue (broken gear stud) So at that time I will be disassembling everything and reseating lots of connections. So I am going to look closely at the connectors for the addition trays. I'll let you know if I find out anything. Should have the right tray guide in about a week, so I won't type back until that is done.
              • luca72
                • Oct 2017
                • 1775
                Re: MP501 quirk
                do as slimslob says (auto continue=on) and also check in printer setup: cancel job with error=off, and auto tray switching=on.
                also check the function command=driver/machine
                if in doubt about the driver, remove the printer and reinstall it with ricoh pcl6.
                "I'll be back"
                • dalewb74
                  • Feb 2018
                  • 1151
                  Re: MP501 quirk
                  just something simple to try, turn off the auto select. and watch what happens.
                  • david.a.pietras
                    • Jun 2018
                    • 1
                    Re: MP501 quirk
                    Oh lord, I haven't been with Ricoh since 2020 and I still have nightmares about that 501 gear stud repair and the cover operated LED lever linkage on the MP401/SP4500 family...
                    Sent from my SM-G781U1 using Tapatalk
                    • tonerhead
                      • Sep 2009
                      • 582
                      Re: MP501 quirk
                      As a followup. I repaired the tray 1 lift (which was scary even for the 2nd time of doing it). I did nothing else as far as programming anything with changes. As soon as tray 1 was repaired, all trays started working as normal. Trays would go from empty to the next available tray just like they should. Weird, but that's what you get with a Kyocera engine and Ricoh firmware I guess.
                      • GIUBOSS
                        • 1433
                        Re: MP501 quirk
                        Weird how it could be from lifting the first tray if only the first one worked. Congrats on fixing that though. It seemed to me a connection problem... One question, initially the machine warned you of the presence of paper in drawers 2 and 3, right?
                          • 37481
                          Re: MP501 quirk
                          I have seen it often when the does not properly work. When enough sheets have fed, the pickup roller no longer has sufficient contact with the paper.
                          • StephenB
                            • Aug 2015
                            • 243
                            Re: MP501 quirk
                            Regarding the 501 dreaded tray 1 lift issue....I have one out there where I added lift springs beneath the paper lift plate. So it gives the paper a "boost" when lifting.
                            The paper loads similar to a 402, then when the tray is pushed in the lift is completed by the lift gears...no knocking. Been working fine for years.
                            • tonerhead
                              • Sep 2009
                              • 582
                              Re: MP501 quirk
                              Yes, originally it knew there was paper in trays 2 and 3. You could just select either and start copying. It may well have been a connection issue though, as I lifted the copier off of the tray 2 to work on replacing the tray lift side guide. All I can say for sure is once the tray 1 was repaired and working, everything worked normally as it should. I did run into a similar one at another location with multiple trays that needed a fuser. I checked apples to apples and all tray settings, etc were the same as the weird one. So it is a mystery that may never be explained. As long as it works as it should, it's a victory for me against the copier demons.
