Ricoh mp c3001
  • cliffhangers
    • Feb 2010
    • 243
    Ricoh mp c3001
    Good day or what ever time it's I'm have problems when I do a photo copy it comes out with tick black line at the top end of the copy.when I print from my computer it comes out clean and good.need help on this photocopy problem. Thanks in advance
    • 37533
    Re: Ricoh mp c3001
    That line is an edge shadow. You need to do image adjustments in accordance the service manual. It shouldn't take more than a couple of minutes.
    • dalewb74
      • Feb 2018
      • 1157
      Re: Ricoh mp c3001
      i would inspect the glass and clean accordingly.
      • sandmanmac
        • 3981
        Re: Ricoh mp c3001
        I think Slim is basically saying the same thing, but compare the copy size to the size of the original in both directions.
        I'm betting that it's reduced, and you're seeing the edge of the paper - and probably only when you use the ADF?
        If so, Adjust the DF magnification in SP mode.
          • 37533
          Re: Ricoh mp c3001
          Also registration and edge erase could require adjustment. There is a section in Replacements and Adjustments on doing all the image adjustments.
          • 1stcavvet
            • Apr 2015
            • 231
            Re: Ricoh mp c3001
            Clean the little skinny glass along the left side of the big glass. alcohol on a rag would do GOOD LUCK
            • GIUBOSS
              • 1436
              Re: Ricoh mp c3001
              Also try to reposition or replace the pressure plate assembly and check if the ADF fixing screws are tight.
