C5300s pro darkness
  • drbing
    • Dec 2016
    • 42
    C5300s pro darkness
    Hi,first of all I would like to thank everyone who helped me last time. Now it is a new device that has worked for about 300 k, it started to leave a dark background, in the place where the paper should be clean. The following was replaced, ITB cleaning unit,PTR,PCU cleaning unit and same happend.Only left is PCU drums.Any help?
    Sent from my SM-A707F using Tapatalk
  • GIUBOSS
    • 1415
    Re: C5300s pro darkness
    It would be better to see a photo of the problem
    • drbing
      • Dec 2016
      • 42
      I don't know how well you can see, but the part of the paper that is not printed on the left should be white like the paper on the right.20230918_101101.jpg
      • GIUBOSS
        • 1415
        It is not clear in the photo but if the background is gray (tending to black), check the maintenance counter of the black PCDU and if necessary clean it or replace it entirely, or if you can even individual pieces (drum, devel., blades, bar wax, winding roller). Are you a technician?
        • drbing
          • Dec 2016
          • 42
          Yes, as I said, everything was replaced, all four PCU cleaning units.
          • GIUBOSS
            • 1415
            I wrote complete pcdu unit
            • drbing
              • Dec 2016
              • 42
              I did not change only the developer. In any case, the machine printed only 300 k. The replacement of drums and developer is about 1 mil.
              • dalewb74
                • Feb 2018
                • 1143
                just because the drum or developer is rated for a certain life count doesn't mean you will get that count...
                • drbing
                  • Dec 2016
                  • 42
                  I know that 5% coverage is calculated, but I just replaced the drums as well. We'll try.
                  • dalewb74
                    • Feb 2018
                    • 1143
                    have you cleaned the ID/Music sensors? what about the lenses for the PCDU?
                    • drbing
                      • Dec 2016
                      • 42
                      ID and lenses cleaned.
                        • 37448
                        That PM figure is based on doing jobs that average over 500 pages.
                        • anothertech
                          • 1766
                          Could be bad potential sensor. Read this bulletin.
                          D0CP_D0CQ_D0CM_D0CN - 023 DIRTY BACKGROUND (D0CP_D0CQ).pdf
                          • anothertech
                            • 1766
                            Check this document, talks about yield vs page per job.
                            Slide 1.pdf
