Ricoh Pro 5210s Question
  • David P
    • Aug 2023
    • 5
    I am printing directly to my Ricoh Pro 5210s (not to a Fiery). When I try to print more than 1 copy, it still only prints out 1 copy. If I try to make 2 copies or 200 copies, it still only prints 1. Thanks in advance!!!!
  • GIUBOSS
    • 1436
    Re: Ricoh Pro 5210s Question
    If you are referring to copier mode, check your copier settings - there should be an entry for the maximum number of copies that can be made to be set to 999 rather than 1, sorry, I read the post again and it refers to printing, then try reinstalling the driver and setting the IP port, or do a test with a laptop by connecting it only to it
      • 37532
      In the driver settings make sure the job type is not set to "sample print "
      • TonerMunkeh
        Professional Moron
        • 3865
        Two things - make sure the media settings you are sending to the machine match what are on it, also of the machine doesn't have a finisher ensure User Tools / Printer Features / System tab "Rotate Sort - Auto Paper Continue" is set "ON".
        Hit it.
        • David P
          • Aug 2023
          • 5
          Your post helped me down the right path. Reinstalled the latest driver. Went into the Printer Preference / Finishing Tab / then changed from "Collate" to "Application". Now everything is working fine. Thank You!!!
          • GIUBOSS
            • 1436
            Well, good work!!
            • Larhal
              • 584
              Well, good work!!
              +1
              Larhal
              If all else fails read the Service Manual!
              If that fails, meet me at the pub and we will discuss it.
