Problem updating fw
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Problem updating fw
    Good morning everyone. for some time I am trying to update two MP9002SP, but the machine does not present me the firmware screen to boot, it tells me that the fw is updated and does not let me overwrite it.
    It is true that one of them already has the latest version, but I am interested in rewriting it because it had some random error code, but the other one has an older version and the same thing happens to me.
    I always follow the procedure of creating the "romdata" folder in the root directory and then copy the files there, I never had any problem until now.
    The same thing happens to me when I try to update a PRO8210.
    Any idea what could be happening?
    Thanks.
    Field technician since 1994
  • luca72
    • Oct 2017
    • 1784
    Re: Problem updating fw
    Any idea what could be happening?....
    Thanks.
    print out the current firmware versions, and test on a PC with "ricoh firmware update tools", see if anything has changed, most models
    they do not allow overwriting, or downgrading...which error code you have?
    "I'll be back"
    • Codex
      • May 2008
      • 704
      Hello
      What kind of SD do you use?, in my experience some machines needs the "old" sd-cards, if you try to update an "old" machine with a SD HC card it fails, or give an SC Error. If you have some old wrecks you can use their cards.
      Memento Audere Semper
      • elmaligno
        • Oct 2009
        • 302
        Originally posted by Codex
        Hello
        The Sd is the same that worked ok in the past with these models
        • anothertech
          • 1771
          Try downloading the SD memory card formatter for Windows from Ricoh to reformat your SD card.
          • luca72
            • Oct 2017
            • 1784
            if remember well, for these model its ideal a size of 512mb, max 1gb (512mb its better)
            "I'll be back"
              • 37533
              It may have failed.
              Are you using Package or individual modules?
              • elmaligno
                • Oct 2009
                • 302
                It may have failed.
                Individual. Formated with Ricoh format tool.
                • anothertech
                  • 1771
                  Are you putting a folder with the product code inside the romdata folder?
                  • elmaligno
                    • Oct 2009
                    • 302
                    No but that firmware is the only one that is on the card, inside the romdata folder that is in the root directory, it always worked.
                      • 37533
                      The proper structure should be:
                      romdata
                      -product code
                      -firmware
                      There some models that may work without the product code folder but not always.
