mp 2014 paper jam
  • Gab
    • Aug 2015
    • 677
    mp 2014 paper jam
    Paper jam at drum before fusing. No obstacle. Cleaned paper feed roller and path. Paper feed roller is almost new. Wnen i cleaned the roller and the paper path it worked perfect for about 200-300 copies but then the same. Can it be something else except cluch?
    • 37628
    Re: mp 2014 paper jam
    Hard to tell without the jam code, the one that is a J followed by a three digit number.
    • GIUBOSS
      • 1437
      Check the flag sensor located in the center of the register roller. One more thing, have you seen the paper stuck if printed correctly?
      • dalewb74
        • Feb 2018
        • 1167
        ricoh parts or no?
        • luca72
          • Oct 2017
          • 1792
          it can be very easily as Giuboss says, the sensor dirty, you can test it with sp-803-003.
          as for the clutch, you can use sp-804-013 for the registration clutch, and sp-804-012 for the paper feeding clutch.
          however, with the jamming code you would go more directly to the problem
          since the sheet stops before the fuser, have you noticed a random movement of the image on the sheet?
          "I'll be back"
          • Gab
            • Aug 2015
            • 677
            error code C and sometimes B but mostly C. I replaced Reg sensor and exit sensor with no result. I noticed that when i copy from by pass no paper jam . Also i noticed when i turn paper to A4 vertical direction there is no paper jam. I suspect geristration clutch . Any idea?
            • Polo-022
              • Sep 2007
              • 486
              Paper end switch actuator has been deformed, or
              the metal base where switch is mounted,
              giving faulty messages to the controller.
              In addition to this, replace friction pad.
              • dalewb74
                • Feb 2018
                • 1167
                care to share the entire error code with us? i have never seen one that just gives a single letter for the code.
                  • 37628
                  Those letters are the location codes for the operator to use when locating a jam to remove it. They tell the service tech nothing as to what sensor or whether lead edge or trail edge.
                  • KeviM
                    • Oct 2019
                    • 327
                    Agreed with Slimslob. You need to give the code starting with J followed by 3 numbers. Eg. J001
                    • KeviM
                      • Oct 2019
                      • 327
                      Also check the registration pressure springs and bushings to see if they are applying the right pressure. They can sometimes crack.
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        ^^^THIS^^^^
                        and it'll be the rear one I'll bet.
                        • Gab
                          • Aug 2015
                          • 677
                          How can see the jam, code. I am not familiar with this machine.
                          for sensor and clutch tests from, what results i concsludce they are defective?
                          • luca72
                            • Oct 2017
                            • 1792
                            In SP's 7, are stored various data about the paper jam, history with time, our, counter, and zone, identifyed by a number code zone.
                            For try the parts, you can use SP 5-804 if i Remember well , but im not in front to the machine now (dont use SP Fuser unit activation on/off on sleeve based Fuser unit without remove waste toner bottle)
                            For test a cluch like paper feed unit with "mono-roller" tendentialy you must remove the paper cassette, put in on the SP clutch, and with the hand try to test the cluch resistance force, must be lock, if too loose or free, replace it
                            For the registration cluch its different, depending of the machine shape, maybe you can hear the click activation sound(?)
                            Or you could try with the door open and the switches activated, to see with your fingers if the registration roller slip... but be careful not to pinch any of your fingers..lol
                            "I'll be back"
                            • Gab
                              • Aug 2015
                              • 677
                              i executed the following programs
                              SP 803-003 result 0x1
                              803-1 (tray paper sensor| result 0x0
                              registration sensor result 0x1
                              paper exit sensor result 0x1
                              P sensor (PWM)) -> executing
                              paper mfeed clutcg -> executing
                              804-12paper feed clutch -> executing
                              804-13 registration clutch -> executing
                              IS there anything above out of order?
