Paper curl at exit for MPCxx03 and MPxx54
  • Popolopo
    • May 2023
    • 136
    Something like image attached. *not the same machine but same problem, you got the point.
    Try lower temperature, turn on decurl. Didn't help much.
    Any help?
  • copyaction
    • Oct 2007
    • 991
    Re: Paper curl at exit for MPCxx03 and MPxx54
    Any help?
    I have had a couple of lease returns of these series that I removed the finisher from and it would do this.
    Apparently when a finisher is installed it uses a different set of exit rollers.
    Possible that is what you are experiencing?
    • Popolopo
      • May 2023
      • 136
      Could you share picture of those exit roller? Which one is the finisher version, version the normal one.
      I know MPCxx04 have that kind exit roller. Didn't notice for MPCxx03
        • 37558
        For the internal finisher the paper enters the finisher through what is the duplex turn around roller for operation with no finisher. On one of the first models to have an internal finisher I had to replace the sensor. The Ricoh help desk said they were getting a lot of calls for that sensor. They gave me a different part number to order. Apparently the turn around sensor didn't have as tight a Hysteresis factor and didn't respond as fast as the original exit sensor.
        • Gift
          • Mar 2011
          • 2459
          Try open and test a fresh realm of paper from your own stock. This looks like an issue with paper quality or room/enviroment climatic conditions (leading to damp paper).
          • Codex
            • May 2008
            • 704
            Had same problem
            Try fresh realm of paper. I know the 04 color series have modified exit rollers D241 4950
            Memento Audere Semper
            • luca72
              • Oct 2017
              • 1791
              Any help?
              the exit roller must have the shape in the photo, if straight ones are not good, they are for the finisher, and cause that problem.
              "I'll be back"
              • Saturn
                • Nov 2023
                • 171
                If you turn the paper upside down, do you have the same problem? What happed if you try SEF feed? Or as Gift and Codex suggested, try fresh paper.
                I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
                • copyaction
                  • Oct 2007
                  • 991
                  This.
                  • havokprod
                    • Oct 2012
                    • 159
                    Hysteresis factor
                    You made me look up what that word meant LOL thank you!!
                    • the phenomenon in which the value of a physical property lags behind changes in the effect causing it, as for instance when magnetic induction lags behind the magnetizing force.
                      • 37558
                      Or optical sensors lag behind changes in light levels
                      • DRichard
                        • May 2008
                        • 482
                        My second wife had a Hysteresis...didn't improve her moods one bit...
                        "Enjoy every sandwich."
                        -- Warren Zevon
                        • dalewb74
                          • Feb 2018
                          • 1163
                          as shown in the photo. you need the fat rollers, not the skinny ones. whenever a finisher is installed, we generally throw out the skinny ones. guess i should probably hang onto one set just in case.
                          • UNICORNico
                            • May 2018
                            • 308
                            Any help?
                            It could also be a case of paper with moisture.
                            I would try a different A4 package.
                            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                            • Xandy_73
                              • Oct 2023
                              • 29
                              This may occur due to the following situations.
                              Wet paper
                              Paper quality
                              So it was cut on the reel at the factory.
