Mp c3004 paper jam code 019
  • Polo-022
    • Sep 2007
    • 486
    Machine jams randomly, paper does not entry into the fuser.
    It curls just under the fuser module and it happens from all trays,
    same thing, even if it is A4 LEF, A5, A4SEF.
    Counter is : 155Κ Βκ & 90Κ Cl total prints.
    Customer use to print only single pages, one at a time...
    I did replace the fuser motor one-way pulleys ( there are 2 of them)
    but the problem remains...
    May i ask your help?
    Thanks a lot.
  • dalewb74
    • Feb 2018
    • 1157
    Re: Mp c3004 paper jam code 019
    firmware? new paper feed rollers in all trays?
    • Polo-022
      • Sep 2007
      • 486
      Firmware is up to date and the feed rollers are at a very good condition.
      No missfeed jams.
        • 37532
        Check the PTR and it alignment with the ITB.
        • emiliorsg
          • Jul 2018
          • 141
          First check that the fuser gears are not broken, which is usual. Also check the status of the PTR unit. If you can try another fuser unit. With that counter it may be in bad condition.
          • TonerMunkeh
            Professional Moron
            • 3865
            A worn fusing sleeve or pressure roller is usually the cause of jams 18 or 19.
            Hit it.
            • luca72
              • Oct 2017
              • 1784
              Thanks a lot.
              can be the bad harness behind the PTR unit (from machine), or sensor, to check quickly, try to change entire PTR unit with harness with another.
              "I'll be back"
              • MIGUELMARCHENA
                • Feb 2018
                • 195
                Personally, if I see that some copy or print comes out randomly and then it gets stuck with this code 019, I disassemble the sleep fuser and apply oil to the heating pad, I clean the inside of the sleeve, I check the bushings, if they are expired I change them etc
                there you will already know.
                  • 37532
                  For clarification, does it curl into a tube like excessive damp paper can do in the exit tray or does it accordion jam as in this image?
                  • Polo-022
                    • Sep 2007
                    • 486
                    It curls just like an excessive damp paper, no dog ears, it never enters into the fuser area. Yesterday i replaced side door interlock switch, today i have reports that it is jamming again.
                    • Polo-022
                      • Sep 2007
                      • 486
                      [ATTACH=CONFIG]60897[/ATTACH]
                      Well, i did the same thought, but i didn't replace it yet, but i will, tomorrow!
                      • Polo-022
                        • Sep 2007
                        • 486
                        My next step will be transfer assy replacement, to check mostly the wiring of fuser entrance sensor and the next fuser replacement, or parts of it. I have to say that there are no broken gears, or worn and it never jams into the fuser, or after...
                        • luca72
                          • Oct 2017
                          • 1784
                          true, J019 happened very often on the mpc2051, only that the fuser there was very ugly to disassemble
                          "I'll be back"
                            • 37532
                            The latches for the paper transfer unit were no piece of cake either.
                            • Polo-022
                              • Sep 2007
                              • 486
                              Fuser Unit Replacement stopped paper jams. It was a premature failure of it
                              and i did not take the risk to re-oil the pad, or to replace it.
                              Thanks again for your support!!
