MPC501SP vs MPC2004ex
  • brianprints
    • Dec 2023
    • 2
    I'm hoping someone can advise me on which used ricoh I should purchase. My main concern is accurate reproduction of photos. It's relative since I'm currently printing from a kyocera ECOSYS P8060cdn. I don't need or have the bandwidth to setup and use a firey. I want something that out of the box or with little effort can produce as photo realistic results at speed (20+ ppm).
    A dealer has two options:
    Ricoh MPC501SP
    <10k prints
    MPC2004ex
    65k prints
    Both are $3,500. I'd like to stay under $5,000 unless there's a huge benefit to going higher which I haven't seen. I was offered a new IMC2500 for $5,775. Any thoughts on these or others is appreciated. Thanks!
  • davel
    • Oct 2011
    • 1095
    Re: MPC501SP vs MPC2004ex
    All of these are made for office colour, photo reproduction is not their strong point. Try samples on all of them.
      • 8131
      Ricoh MPC501SP
      <10k prints
      MPC2004ex
      65k prints
      Of these 2 I would go with the MP C2504ex however this is the entry level model if you can get the next model up the MP C3004ex this is a significant improvement.
      However are you aware these models are have been discontinued, so I assume the quotations you have are for 2nd hand devices?
      • dalewb74
        • Feb 2018
        • 1135
        you know laser copiers don't mix well with photo gloss paper?
          • 37379
          There are a few photo glossy papers that do work. Check the label. They will be labeled to say for use in laser printers.
          • Oze
            Ricoh Fanboy
            • 1663
            We generally recommend Toshiba AquaAce...it gives users the least trouble we've found.
            • brianprints
              • Dec 2023
              • 2
              I was leaning towards that one too. What does the 3004ex have that the 2504 does not? I thought it was just ppm differences.
              • Gift
                • Mar 2011
                • 2458
                  • 8131
                  The MP C3503ex uses better quality PCDU (drums) with a much longer PM life this produces better print quality but yes also faster PPM.
                  For that price I'm sure you could buy / lease a brand new IMC range
                  • dalewb74
                    • Feb 2018
                    • 1135
                    yeah i agree totally. but we know most people don't read the label. and you know what happens with the wrong paper in a laser copier. has been awhile, but i have seen scorched paper inside a machine.
                      • 37379
                      Yeah with a lot of photo glossy paper for inkjet the glossy is a thin plastic film on the paper. It melts and adheres to the fusing belt.
                      • copyaction
                        • Oct 2007
                        • 985
                        Ricoh MPC501SP
                        <10k prints
                        MPC2004ex
                        65k prints
                        I would look for another dealer. Those prices are way high.
                        • luca72
                          • Oct 2017
                          • 1748
                          Ricoh MPC501SP
                          <10k prints
                          MPC2004ex
                          65k prints
                          depends on what kind of quality you mean, with new consumables, and the correct settings in the driver (thick paper, high resolution, and quality mode) you can get really good results, as long as the drums and everything are new, as someone says here, although excellent, they are office machines, not for taking photos of weddings and baptisms, or photographic exhibitions, even if the result is really excellent, I personally have printed a lot of DVD covers for myself, and nothing to say about the quality, the price is really exaggerated, if you were a dealer and you find the right supplier, with half, or even less, you would take home a remanufactured 2004 with almost all new parts and the counter reset... if you are a dealer in the sector ...Obviously
                          "I'll be back"
