Ricoh MP C3004ex black drum unit procedure
  • copykat93
    • Oct 2021
    • 259
    Hi guys, I picked up a new customer this morning, and when I was speaking with her on the phone yesterday, she told me they were getting black lines only when they fed stuff through the document feeder, she said if she laid it on the glass no lines, and if they sent a print job there was no lines. I thought this will be easy breezy, I went there this morning (45 miles one way) and she lied to me!! It prints and copies from the glass and dock feeder with lines on pages. An internal total page count print out shows a couple of lines on the sheet . There's not a lot of lines, but it definitely happens from printing as well.. anyway, My question is.... Is there a procedure that I need to know in order to change out just the black drum unit, not the developer unit? But I'm actually looking to have some guidance in replacing just the black drum unit and the procedure to do that. Also, is there a place where I can get this at a reasonable price? eBay is outrageous, precision roller is pretty high, and they don't have it in stock either. Is there any Ricoh guys in here that are willing to maybe sell me the black drum unit for the MPC3004EX machine? If you are willing to, send me a message through email /private message. It would be greatly appreciated.
    I found a few drum units on eBay, but they're in China and it will be until March before it would be delivered.
    • 35633
    Re: Ricoh MP C3004ex black drum unit procedure
    The problem is a dirty "slit glass". That is the narrow glass that the originals slide over during scan. Use an alcohol prep to clean it.
    • copykat93
      • Oct 2021
      • 259
      I'm guessing that you didn't see that I wrote, I get the lines from the internal prints also, so it's not a scanning issue, that's what the customer told me she was having, was a scanning issue. But when I arrived I get the lines with internal prints, so I wanted to replace the black drum unit, I'm looking for that procedure including service mode as well.
      • Lord F
        • Oct 2023
        • 6
        The issue will be contamination of the charge roller - this will be because the lubricating bar has worn away. Remove the charge roller unit from the bottom of the PCU housing and you will probably see lines that match the location of the lines on the printed page. Gently clean this roller with water (NOT alcohol or anything similar as it will remove the conductive coating) and refit back into the unit. You will have print a few pages just to clean up the image but then should be OK. This is only a short term fix as the charge roller will get contaminated again due to the depleted lubrication bar. Depending on the volumes, it may be worthwhile cleaning the charge rollers of the other PCDUs as well whilst you're in there. You can change just the black unit (indeed CMY also), they are designed to be separated and fitted independently of one another as the dev unit PM cycle is greater than that of the PCU.
        • copykat93
          • Oct 2021
          • 259
          Thanks guys... I did clean charge roller & still 2 lines, that's why I was wanting to do the Black drum unit. I need the black drum unit & the procedure to replace it, I have split these units on similar models, but not on this model. That is why I was asking for the procedure to replace the black drum unit only. Like simulation mode & what other procedures are involved in sim mode to make sure I do it correctly? Do you have a recommendation or a contact for this drum unit that I need? Thanks a bunch
          • CopyBats
            • Aug 2011
            • 133
            Not posting youtube videos because I do not want to promote spare parts from any given company. A Youtube search of MP C3004 drum rebuild will get you the info you need.
            Fair warning, Ricoh PCDU's are one of the most expensive in the copier industry. You will be surprised by the replacement cost of the full unit if you damage the developer or other parts during this.
            If it works, don't touch it.
            • dalewb74
              • Feb 2018
              • 1091
              have you removed the PCDU to inspect it?
              • copykat93
                • Oct 2021
                • 259
                Come on man, of course I did!! I don't work on a lot of Ricoh's, so I came in here to ask for some guidance, that's all, my main line of machines is Kyocera... I picked up a new customer and thought I could help her, but I wanted to be sure if I'm able to find just the drum unit, I do not want to rebuild the drum unit I want to find a drum unit assembly that does not include the developer unit with it. If I can find that for a reasonable price, I wanted to be sure that I do it correctly, on install after splitting and adding the new drum unit, what do I do in simulation to let the machine know that a new black drum unit has been installed? It's really not that difficult of a question, I just wanted to be sure I do the customer justice in making sure that I install it correctly and use the appropriate simulations. I apologize if I'm in a group that maybe doesn't want to help a guy that works on Kyocera, my apologies. Have a great day.
                • CopyBats
                  • Aug 2011
                  • 133
                  Mate this isn't a Ricoh vs Kyocera thing. It's just techs being careful because we often get end users coming here to try to fix a machine that needs a proper technician.
                  I already suggested to you on YouTube what to search for. If you had searched it you would have seen the SP mode at the end of the videos.
                  Anyways a quick Google search will show you service manual for this. There is another user here that sells them.
                  I don't distribute it as I don't want problems with Ricoh
                  • Larhal
                    Retired Part Time
                    • 432
                    Check Your PM...
                    Larhal
                    Retired Part Tired
                    If all else fails read the Service Manual!
                    If that fails, meet me at the pub and we will discuss it.
                    • copykat93
                      • Oct 2021
                      • 259
                      Thank you very much guys!
                      Have a great day!
                      • sandmanmac
                        • 3956
                        Relating to cleaning the Charge roller......
                        When I get lines, I've never had luck with simply cleaning them 'gently', so I remove the PCR, and scrub it with a cleaning solvent and Scotch brite pad right down to the white nylon. The coating comes off like a messy scratch ticket.
                        The wax bars are usually still good, but I do replace the foam cleaning roller.
                        I typically carry a couple of cleaned and serviced units with me and just swap them in in the interest of time, PLUS it's a messy job to do on site.
                        I'm not sure what others think about that, but it's never caused me a problem, and it usually extends the drum life and saves me $$ in the case of Maintenance agreements, and as for my T&M customers, I don't make any promises to them, but it has generally resulted in the machine working well for a decent amount of time - almost every time, and saves them some $$
                        Most recently I had a C3503 black drum unit go almost an additional 1 year / 80K with a scrub.
                        I've been doing this for ages going back to the OLD MP C3000/3500, etc., going back to the late 2000's.
                        BTW, the same holds true for the smaller MP C306's, etc.
                        • copykat93
                          • Oct 2021
                          • 259
                          Great info Sandman... I too have been servicing office machines for a long time as well.. since 1986, I cut my teeth on the old Mita machines, even a couple liquid ones & then the coated paper machines. This industry has been good to me. I have been doing it on my own since Feb 1st 1993, so tomorrow will be my 31st year in business on my own. I love having this site for all the knowledge from the different manufacturers.. I appreciate you all!!
                          • copier tech
                            • 8010
                            PCU (Drum) replacement is covered in the service manual.
                            However you may find all that is needed is the charge roller replacing, a lot cheaper than the Ricoh PCU.
                            • Larhal
                              Retired Part Time
                              • 432
                              If The Charge roller is scored with a line around it you will need to replace the drum cleaning blade as the score is from a defective cleaning blade. otherwise the problem will happen again in the same place.
                              Larhal
                              Retired Part Tired
