Ricoh MP C4503 SCANNED DOCUMENT PRINT ISSUE
  • ahjie0608
    • Apr 2017
    • 3
    [CQ] Ricoh MP C4503 SCANNED DOCUMENT PRINT ISSUE
    Try to print out scanned document, PDF format and this happened.
    Original document look just fine when preview from PC.
    I hope you can help me with any suggestions or comments.
    Thanks in advance
  • mrwho
    Major Asshole!
    • 4299
    Re: Ricoh MP C4503 SCANNED DOCUMENT PRINT ISSUE
    That's an heavily compressed document - those are compression artifacts.
    You might be able to see them on the computer screen if you change your viewing angle (try looking at the screen from the bottom up).
    The only solution I can think of is to scan the documents with less compression.
    Mascan42
    Ibid
    • RMC8112
      • Nov 2019
      • 38
      Change the scan settings from Photo to Auto color setting.
        • 37062
        IMHO Auto Color is never good to use
        • luca72
          • Oct 2017
          • 1711
          Thanks in advance
          [ATTACH=CONFIG]61428[/ATTACH]
          so by eye, I see some shadows, it seems to be set to photo mode (which is not the best for a document)... put text mode... you have to play a bit with the resolution and compression settings.
          • rthonpm
            • Aug 2007
            • 2847
            Used it for years with no issues. The key is to also make sure the scan is bumped up from the fax quality 200x200 to 300x300, which is more suited for documents and cleans up a lot of issues that the lower resolution leaves behind.
