mpc400sr with sc797 defective sensor solenoid
  • fshead
    • 2376
    greetings
    i got a text with a machine with intermittent sc797 code
    no 797 in manual but a vague bulletin for sc797..
    sensor solenoid error
    i am trying to figure which solenoid in sorter b4 hitting account and i can assume the mpc401 sorter parts excluding brds should work?
    thanks
  • luca72
    • Oct 2017
    • 1784
    Re: mpc400sr with sc797 defective sensor solenoid
    Originally posted by fshead
    greetings
    thanks
    never happened, I really struggled, this is what I found, this is bad code.
    -if you have one, I would try another finisher
    -clean and lubricate the stappler unit axle (sometimes the overload make strange tricks)
    -clear all possible hp sensor, and reset all connectors.
    anyway:
    797 D NVRAM data error
    1. Check the harness connection.
    2. Replace the main board.
    "I'll be back"
    • fshead
      • 2376
      from what i see there is only 1 solonoid on this sorter.
      its on the bottom with a sensor.
      i am pulling a mpc401sr sorter and i think the sr1000 sorter is the same for the mpc400sr..
      i dont have any 400 series anymore..
      • MIKON
        • Jul 2015
        • 188
        90% of the problems I have seen with that finisher is the motor cushion breaking and the belt falling off or slipping.
