I currently have a Ricoh IM 5000 with an internal finisher, model SR3250. The problem I'm experiencing is a late jam while exiting the finisher, the page will stop either a quarter or half way out. There are no visible obstructions, or sc codes. What makes it more confusing is that the jam only occurs when the paper is in the paper tray in the portrait position. When the paper is situated landscape, there are no jams and prints without issue. I've tried switching control boards on the copier and finisher, changed the plug in point for the finisher, updated firmware and even switched entire finishers. Any advice is welcome, thank you in advance.
SR3250 Internal Finisher Late Jam
Re: SR3250 Internal Finisher Late Jam
I had a problem like that. Try running out of a different paper cassette. Turned out in my case, the cassette guides were off to either the front of rear a little. That caused the side to side registration to be off, the internal finisher couldn't cope with it.Comment
I currently have a Ricoh IM 5000 with an internal finisher, model SR3250. The problem I'm experiencing is a late jam while exiting the finisher, the page will stop either a quarter or half way out. There are no visible obstructions, or sc codes. What makes it more confusing is that the jam only occurs when the paper is in the paper tray in the portrait position. When the paper is situated landscape, there are no jams and prints without issue. I've tried switching control boards on the copier and finisher, changed the plug in point for the finisher, updated firmware and even switched entire finishers. Any advice is welcome, thank you in advance."I'll be back"Comment
