im-c3000 firmware
  • ksp
    • Oct 2013
    • 22
    [Misc] im-c3000 firmware
    A friend showed me how to install firmware on IM-C3000 through SP - update firmware ...etc but it seems to take about at least an hour. someone else suggested that if I had the firmware on a thumb drive it would only take about 20 min or so. If that is true how would I acquire the firmware? can someone send it to me, or can some one suggest where to buy it from.
    So sorry to bother ya'all with such common stuff in this day and age but I getting to be kind of an old fart (pushing 70) and haven't dealt much with computers and such since win 2000. and the last copier that I was factory trained on was the Savin LTT 890 & 5040 liquid copiers. since then I have been just buying the manuals, reading them from cover to cover and going out and figuring it out. I have had a few friends along the way that have helped me out from time to time but most of them have either retired, quit the biz, or passed away.
    So.....needless to say any help would be very much appreciated. Thank you all in advance.
  • anothertech
    • 1766
    Re: im-c3000 firmware
    Just set SP5886-111 to a 1
    Then it will update itself automatically.
    • copier tech
      • 8138
      We can supply the latest firmware that you can use to update via USB pen. This is the safest & quickest method.
      • Saturn
        • Nov 2023
        • 171
        Yoz can also use the Ricoh Firmware Update Tool, this is the easiest way.
        I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
        • ksp
          • Oct 2013
          • 22
          Thank you all for your input, But I was hoping someone would maybe send me the firmware to my email zipped and I could unzip it and put it on a thumb dive or something.
          • ksp
            • Oct 2013
            • 22
            Is the firmware the same for the IM-C2000, C3000, C4500, C6000 ??????????? update #7.2 ????
            • Saturn
              • Nov 2023
              • 171
              There are 2 different firmwares, IM C2000 - C3500 and IM C4500 - C6000
              • Saturn
                • Nov 2023
                • 171
                I think that's not possible. The download file of the package firmware is allready zipped, it has has about 693 MB.
                • anothertech
                  • 1766
                  Why are you not turning on auto update? Turn it on, I should be all updated by Monday.
                  • luca72
                    • Oct 2017
                    • 1762
                    as they have already suggested above, go to google and write "ricoh firmware update tools" download it, and update the machine in 10-15 minutes, this is more than enough for your machine, the file is pkg and is too large for send it to you and you would waste a lot of time to get the same result
                    "I'll be back"
