Cant open wim in any browser , he search ip on web(?)
  • luca72
    • Oct 2017
    • 1778
    Hi everyone, it often happens that by typing the machine's IP into the browser, instead of opening it, it searches for it on the internet.
    I usually type [win]+[R] and type "http://(ip address)" and it works, or I try from another browser, and somehow I manage to connect.
    today it happened to me on a PC that even when "run" opens the browser in internet search mode for that IP address, have you encountered this problem? Have you found a solution to ensure that the IP is executed and not searched on the web?
    "I'll be back"
  • KeviM
    • Oct 2019
    • 324
    Re: Cant open wim in any browser , he search ip on web(?)
    Hi. I think it's possible to open it under network devices when checking all devices available on your network
    • luca72
      • Oct 2017
      • 1778
      I have installed the machine (mpc3004) with ip port without problem One minute first, and advanced ip scanner found the machine, but the browser take the ip address in search mode instead of open the page
      "I'll be back"
        • 37490
        What browser are you using?
        What is the first DNS on the C3004? If it is not local, local domain server or local router, that can cause the problem.
        Have you tried connecting using the NETbios name?
        • dalewb74
          • Feb 2018
          • 1153
          there is no need for you to type http. just type the IP address.
          • luca72
            • Oct 2017
            • 1778
            the DNS are those of the modem, plus cloudflare, and google....but the other PC doesn't have this problem, it doesn't even work when running, I tried with edge, chrome, and firefox, nothing.
            first wim worked from that station (there are only two laptop PCs) then the customer changed the PC, the scanner will certainly work, but I can't access the mf from that PC, he searches for the IP on the internet instead of opening wim
            "I'll be back"
            • luca72
              • Oct 2017
              • 1778
              I mean in "run" (win+R)....are you sure? I seem to remember that from there you have to put http(?)
              "I'll be back"
                • 37490
                Try using local://IPaddress and see if that forces it to search the local network.
                • luca72
                  • Oct 2017
                  • 1778
                  Good idea, I have to connect with the client remotely on Monday afternoon, I'll try
                  "I'll be back"
                    • 37490
                    Just thought of one other thing. Is the PC in question using a VPN such as Nord, Norton or something similar or a proxy? If so, that is the problem. The browser can only see what the VPN or proxy server can see and that server is not local.
                    windows - Why can I access Internet but not local devices over VPN (wireguard)? - Super User
                    • luca72
                      • Oct 2017
                      • 1778
                      no, it's a very simple network, a modem, two laptops, and the 3004, it doesn't use VPN, I often have this problem, but at the beginning I changed browsers (with Firefox Wim usually always opens) but then I started to always use "run" and I've never had problems, but this time it doesn't even open with that, I think that as you say "local://ip_address" by nose has a good chance of forcing the connection to wim, instead of doing a search on Internet of the IP.
                      "I'll be back"
                      • dalewb74
                        • Feb 2018
                        • 1153
                        what happens if you ping that IP address from the computer you are trying to use to get to the WIM?
                        • luca72
                          • Oct 2017
                          • 1778
                          the ping to mp3004 work well, with the ping command the machine is seen on the network, (it prints easily) but the browser's (all) open and look for the IP on the internet, instead of opening wim
                          "I'll be back"
                          • luca72
                            • Oct 2017
                            • 1778
                            hi, I tried it in the lab, and the "local" command is not recognized
                            "I'll be back"
                            • mrwho
                              Major Asshole!
                              • 4299
                              That's an odd one. Do the other computers access WIM without any problems?
                              Mascan42
                              Ibid
