IMC3000/3500 Shortcut Scan To folder
  • GeorgeBest
    • Jul 2009
    • 526
    Someone experienses this problem before?
    can't understand why this difference arises. . .
    thanks in advanced
    • 37628
    Re: IMC3000/3500 Shortcut Scan To folder
    Check to see if they all have the same firmware levels.
    • dalewb74
      • Feb 2018
      • 1167
      ok i am trying to wing it on the language thing on the photos. but it looks like you have scan to email selected, but you are trying to scan to a folder? you have to select the drop down and select scan to folder. does the file path appear then? you did this in the address book?
      • GeorgeBest
        • Jul 2009
        • 526
        I will check . .
          • 37628
          I didn't even see that.
          • luca72
            • Oct 2017
            • 1792
            BINGO!
            "I'll be back"
            • dalewb74
              • Feb 2018
              • 1167
              a few will let you set the scan to folder as the default. but from what i have seen, very few. i always try to tell my customers you have to hit that drop down, if you wanna scan to PC.
              • UNICORNico
                • May 2018
                • 308
                I will be honest. I prefer the Classic application, it is less cumbersome and the main thing is directly, and not through secondary accesses.
                One thing that changed in the clients and in the machines we installed, the new design is not comfortable at all, for small last minute adjustments, and many clients get used to not adjusting anything, they expect that by "Art of AI" everything will adjust automatically. It's exasperating.
                "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                • copier tech
                  • 8220
                  Same, we set all our new devices with the classics legacy apps only & delete the 'new' apps off the home screen.
                  Lucky the new C3010 series still have this option.
