ricoh mp402 printing problem
  • LEONE
    • Feb 2024
    • 37
    printing problem - new original drum, fuser ok - total ricoh mp402 printing is 22000 -
    riccardo.jpg urgent-
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ricoh mp402 printing problem
    Paper lever on the fuser set to envelope?
    Hit it.
    • LEONE
      • Feb 2024
      • 37
      Originally posted by TonerMunkeh
      Leva della carta sul fusore impostata su busta?
      NO - IS OK
      • Polo-022
        • Sep 2007
        • 486
        Background all over the page i can see. Is this your problem?
        • LEONE
          • Feb 2024
          • 37
          REPEAT THE IMAGE.
            • 37532
            [ATTACH=CONFIG]62386[/ATTACH] urgent-
            New drum or complete PCU???
            It appears that the drum is not being properly charged.
            • luca72
              • Oct 2017
              • 1784
              I can't see well....but don't you have a better photo?...at least describe the defect.....mannaggia'a maronn!...LOL
              "I'll be back"
              • anothertech
                • 1771
                I will respond there if you cover my travel. I haven't been to Naples in a while.
                Otherwise, stop the machine when the paper is in it to determine if it's drum or fuser.
                • Codex
                  • May 2008
                  • 704
                  hello
                  Had this problem with two MP402, need to replace entire fusing unit.The problem occurs after a few prints, not immediately
                  Memento Audere Semper
                  • LEONE
                    • Feb 2024
                    • 37
                    Originally posted by codex
                    hello
                    had this problem with two mp402, need to replace entire fusing unit.the problem occurs after a few prints, not immediately
                    resolved . Firmware update . Ok
                    a thousand thanks .
                    • anothertech
                      • 1771
                      a thousand thanks .
                      Everyone reading this should learn from it. Update EVERY Ricoh ever made if you have access to the firmware, this heads off so many problem. Most techs I know just don't do it.
                        • 37532
                        I used to down the newest firmware every Monday morning so that I would have them on my laptop. When CXX03s came out is was every day for a few months just to try to keep up with the SC899 fixes.
                        • Codex
                          • May 2008
                          • 704
                          Done this for 15 jears... And till now. Some issues are fixed with Firmware Update... But you are right... I also know some techs that dont use to update Firmware
                          Inviato dal mio SM-S901B utilizzando Tapatalk
                          • copier tech
                            • 8172
                            So true, but but not doing regular updates when you really do NEED to update you can run into issues jumping up from factory to later etc.
                            • Saturn
                              • Nov 2023
                              • 171
                              We have been activating ARFU for several years now when pre-installing the machine. Ricoh has been delivering the devices pre-configured for about a year now. We haven't had any problems with this so far.
                              I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
