Anyone have the tech bulletin when replacing the magenta dev unit. Thanks
MPC 5503
Re: MPC 5503
As it appears to me, the COLOR Development Units should support more than 270K of work.
But it all depends on the use, and the type of work that is required of the device and said units.
Although sometimes it is a lottery."ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator. -
Re: MPC 5503
there isnt bullettin about, the procedure is on the manual, preferably first of replace, you must go in sp mode and put to 1 the sp3-701-* , and reboot the machine.
*=interested unit for replace"I'll be back"Comment
Re: MPC 5503
is that the one that discusses removing the seal? and either you flip the spring or not? and then reattach the new seal? the ones that i have seen have a sheet with the instructions on it. if that is what is being referred to.Comment
Re: MPC 5503
Make sure to completely remove the orange tape. The ribs may break inside the unit, if you remove the
preset seal without removing the orange tape. As a result, broken ribs may fall into the Development Unit
and cause white lines to appear on the printouts. See the photo below. See Removing the PCDU Preset
Seal Procedure for the correct method for removing the sealComment
