Imc2500 reboot after card insert e32 error
  • Rahul_spbs
    • Jun 2020
    • 11
    Hi All
    had a client where the machine was stuck on please wait screen
    we brought the machine into the workshop and tried to resolve the issue and we did every thing from trying to reset the screen to factory mode and even updating the firmware.
    when we tried the firmware update the machine froze half way through. we left it over night and when we came back the machine was still stuck and my technician shut down the copier hoping to recover from firmware point. I know this is a no no and have now had to change the controller board but I get the error Reboot after card insert E32 METMF3Aa_eplot even after changing the CB.
    how do I rectify the issue on the machine?
    ANY LEADS?
    • 37490
    Re: Imc2500 reboot after card insert e32 error
    I take it that you were trying to use the not always dependable Ricoh Firmware Update Tool. To recover from the error you will probably need to do an SD card firmware update.
    On the computer used to run the RFUT there should be a temp folder that contains all the .fwu and .zip files that were downloaded.
    • Codex
      • May 2008
      • 704
      Used this tool only once... Too slow... Updates a single firmware, and then reboots the machine.... Is this the normal behaviour??... After that i never tried again
      Inviato dal mio SM-S901B utilizzando Tapatalk
      Memento Audere Semper
      • luca72
        • Oct 2017
        • 1778
        yes, it's normal, with that method during the update, the machine makes movements, and restarts several times
        "I'll be back"
          • 8144
          Originally posted by Rahul_spbs
          Hi All
          ANY LEADS?
          Try the reset procedure reset 143 C x3 device should beep 3 times then restart the device.
          • luca72
            • Oct 2017
            • 1778
            Hi All
            ANY LEADS?
            try to do as "copier tech" says, + insert the SD with only the system copy in the romdata folder
            "I'll be back"
            • UNICORNico
              • May 2018
              • 308
              Hi All
              ANY LEADS?
              "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
              • anothertech
                • 1769
                1+ with this procedure. It got me out of a bind before.
