Ghosted copies and fusing web gets stuck to the hot roller, Changed hot roller pressure roller bearings cleaning roller fusing lamps . The copy is five stars before entering the fuser.
Aficio 9005 ghosting
I don't know what that model is and can't pull it up with http://tscweb.net/modelxref/
But we had that happening with a Aficio 2051SP and we were using the wrong fusing web. The Aficio 1075 fusing web isn't the same. Other than that, Fusing web bearings replaced? PM item on most big machines. All gears look good in fusing web assembly? Had one unit where the Gear is one way and there is a metal tab that rides on it so it clicks that direction only. The gears teeth became brittle over time. -
Does the machine uses original toner? Hot Roller and Web?
verify the web gears perhaps one of them is damage... and SP 1902 ** were not played...
Good Luck.fix the customer first then fix the machine... its simple and makes life more easy.Comment
But we had that happening with a Aficio 2051SP and we were using the wrong fusing web. The Aficio 1075 fusing web isn't the same. Other than that, Fusing web bearings replaced? PM item on most big machines. All gears look good in fusing web assembly? Had one unit where the Gear is one way and there is a metal tab that rides on it so it clicks that direction only. The gears teeth became brittle over time.sigpicWe can all Win, but at the end we all loose. Save the greyhoundComment
Thanks Imind for the link.
I've barely touched machines over 75CPM. You say the web is a new assembly. Does that include the motor on the end? Some Assemblys come with or without that.
Not enough air flow in their? Clogged filters/Fans?
On 2575 I've seen that Slide out bar filter so dirty it caused issues.Comment
aficio 9005 is a ricoh 2090 in a instant. Know hard feelings...
this link may come handy:
Ricoh Copier Equivalency List we support all these machines in the Crawley West Sussex and Surrey area.
The RICOH AF2090 is The correct model reference... The 9005 seems to be the NASHUATECH equiv, BUT, as NASHUA are now part of RICOH, please post the RICOH model number, or mention that you work on the NASHUA kit rather than telling others to use google!!!Comment
If so, may cause the hot roller to atract toner and the web to stick.Comment
that would explain why..... yeah right using original katun.....fix the customer first then fix the machine... its simple and makes life more easy.Comment
Listen my friend, why dont you help, most of your replies are only shit, as you can see or search most of my posts is giving help.
Im not a rookie:
google this song in MP3 format> The Cure, killing an Arab, hehehe.sigpicWe can all Win, but at the end we all loose. Save the greyhoundComment
yeah you can say most of my replies is a shit.... i'll take note of it... thank you. with due respect sir, as i far as i know, people post here to seek help and to help. we are not competing, share and seek ideas to have better, easy job. regardless of rookie or experience engineer its a matter of attitude, bieng open to any ideas, i guess we mis understand, and am sorry for that.fix the customer first then fix the machine... its simple and makes life more easy.Comment
yeah you can say most of my replies is a shit.... i'll take note of it... thank you. with due respect sir, as i far as i know, people post here to seek help and to help. we are not competing, share and seek ideas to have better, easy job. regardless of rookie or experience engineer its a matter of attitude, bieng open to any ideas, i guess we mis understand, and am sorry for that.sigpicWe can all Win, but at the end we all loose. Save the greyhoundComment
