thin black line appears when using ADF 2-side copying in aficio1060
  • aaahmmm
    • Aug 2009
    • 103
    I had a problem in aficio 1060 ,only when I made a 2-side copying using ADF a vertical thin black line appears in the back side of the output copy , I cleaned the scanner of the ADF well but the line still appears .
    What do you think the problem?
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    • Eric1968
      • 2458
      Did you also clean the shading plate? If the CIS is really clean and the line won't go away, I think you have to replace the CIS.
      • TonerMunkeh
        Professional Moron
        • 3865
        I'd put money on a little bit of dirt on the CIS glass. Clean it with IPA solvent.
        Hit it.
        • Iommanxman
          • Aug 2009
          • 180
          Check that the white reference plate is also clean. Both on the underside of the DF and under the platen glass. If either of these get dirty it can cause wierd faults.
          • aabarnes1
            • Mar 2009
            • 620
            You must also adjust your margins in user tools, document features,edit,back margin.I take it this is on the second side of a duplex copy???
            Grant me the serenity to accept the things I cannot change.
            • paulg
              • Jun 2007
              • 278
              My first thought as well
              • schooltech
                School District Tech
                • Jun 2008
                • 504
                You might try changing the margin shift from .2 to .0. I also think that this is the problem.
                Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
                • Iommanxman
                  • Aug 2009
                  • 180
                  This is a very common problem and one that comes as a default when new. Go into user tools. Click coper/document server and go to the edit tab. On there you will have an option for 1/2 sided margin adjustment. By default as new it comes set to 0.5mm. You need to change this to 0mm and that will instantly cure the problem. This is usually one of the first things I do when setting up a new machine. Good luck.
                  • imaginemoko
                    unTrusted Tech
                    • Jan 2008
                    • 289
                    if the original is feeding on LEF, then having a thin line either trainling or leading... as mention above go to Edit Margin...
                    good luck...
                    fix the customer first then fix the machine... its simple and makes life more easy.
                    • aaahmmm
                      • Aug 2009
                      • 103
                      thanks to all who try to help me
                      but the thin black line place in the middel of the page
                      • Iommanxman
                        • Aug 2009
                        • 180
                        If that is the case then its going to be a dirty/faulty rear CIS unit which is inside the DF or you have dirty optics if it's on the front side. Obviously you have checked that it does not put lines on an SMC print to check that it is an optical problem and not a print problem?
                        • Brave Hart
                          • Aug 2009
                          • 73
                          If all above fails you have a faulty CIS i once had it that it pulled thin black lines across the page! I also had one were the wire brakes in the loom rite by the cable tie.
                          Good luck
                          What? HuH?
                          • bat
                            • Sep 2008
                            • 140
                            I had a few cases in wich CIS glass had a tiny scratches or cracks, and dirt during copying is stuck in this cracs wich couses black lines. This dirt canot be cleaned easily You have to take out the CIS form DF and take a good rub, or replace it of course.. Hope this helps...
                            • gernah
                              • Jun 2009
                              • 57
                              Sir,the vertical thin line is located top,center,down of your copy output?so that I can analized your problem.Please reply immediately,thanks
